4A-GE 20V ITB bolt patterns
02-17-2016, 12:15 PM
Just a shot in the dark here, but has anyone by chance compared the 20V ITB bolt patterns between silvertop & blacktop?
The bolt holes that the plenum / velocity stacks / trumpets bolt into.
I do know that the gaskets have different part numbers between versions and that the bore size is different but that doesn't mean that the bolt pattern isn't the same.
I only have silvertop gear myself, and Toyota Finland is having problems delivering a blacktop gasket for me, otherwise I would have compared the gaskets and be done with it.
Thanks Smile
Kajoba Works - TIG-welding & custom fabrication services
http://www.kajobaworks.com
http://www.facebook.com/kajobaworks
+358458872222
02-17-2016, 10:27 PM
Blacktop....
[Image: AEU86 AE86 - 4A-GE 20V ITB bolt patterns]
Not my pic but it looks to be correct.
Cheers... jondee86
02-18-2016, 03:40 PM
Cheers jondee86!
So yes, the pattern is quite a bit different on the silvertop, as the up-down spacing is 72mm instead of 84mm. Also more than probably the throats are further apart from each other on the blacktop.
I'll just have to keep on bugging the finnish dealer to order me a gasket to draw flanges off of.
Thanks!
+358458872222
02-18-2016, 10:35 PM
(02-18-2016 03:40 PM)kjb Wrote:  Also more than probably the throats are further apart from each other on the blacktop.
AFAIK the ITB spacing matches the cylinder bore spacing, and that will be
the same on the silvertop and blacktop. So while the throat size is larger
on the blacktop, the spacing centre to centre should be the same.
Cheers... jondee86
02-19-2016, 01:14 PM
Cheers... jondee86
Yes, now that I look at the silvertop itb's there does seem to be ample room between the throats even when taking into account the larger throat on BT.
I guess we'll see when I get a chance to compare the gaskets Smile
+358458872222
02-27-2016, 12:08 PM
(02-17-2016 10:27 PM)jondee86 Wrote:  Blacktop....
Cheers... jondee86
FYI Dimensions are wrong on that.
Andrew
02-27-2016, 12:09 PM
@KJB
I can order gaskets here in Ireland and post, I already send parts to Finland.
02-27-2016, 01:23 PM
Thanks for the offer, but Toyota Finland eventually managed to complete my gasket-order. Hoping to get my hands on it in the next month or so Smile
(02-27-2016 12:09 PM)mannix20vt Wrote:  @KJB
+358458872222
  Cam Cap Bolt Snapped!! Alex170984 1 5,790 06-08-2018 01:17 PM
  crank 6 bolt flywheel DJexor 5 11,258 12-05-2016 08:21 AM
Last Post: d3nso
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 6,312 03-22-2016 09:43 PM
Last Post: ditn
  How to install 20V ITB on 16V head Mr.komp 7 15,951 12-28-2015 05:35 PM
Last Post: pack
  Camshaft sprocket bolt size? harkes 1 6,489 07-03-2015 12:41 PM
Last Post: Dave W
