20V cams - CATCAMS vs KELFORD?
03-27-2010, 07:49 AM
I have 10mm lift 288 degree Kelford Cams in my 20v Blacktop with VVT.
06-16-2010, 11:34 AM
4000GT Wrote:I have 10mm lift 288 degree Kelford Cams in my 20v Blacktop with VVT. so with running this setup did u change the springs and valves?? if first u dont succeed,ur not trying hard enough |
07-03-2010, 01:57 PM
I would like to see the dyno graph of that 4000GT
07-03-2010, 09:34 PM
20vPETE Wrote:4000GT Wrote:I have 10mm lift 288 degree Kelford Cams in my 20v Blacktop with VVT. Stock valves and Performance Springs from Aussie! This cant use cams with VVT is a myth from AE86DC. Its ALL about how they are dialed in. |
07-04-2010, 02:16 AM
has your valve to piston clearence been measured?
07-04-2010, 02:53 AM
Sam-Q Wrote:has your valve to piston clearence been measured? Everything has, thats what the engine builder does when they dial everything in... |
10-11-2010, 11:26 PM
Hello guys. I have an AE111 blacktop. I want to keep VVT and buy some catcams camshafts. I will go for 260 in both sides with 9mm lift. I am currently have a Mine's ECU on my car.
Will this setup work? If head skimmed and a TRD headgasket 0.8mm used, will it still work with the VVT? Thanks! |
03-19-2011, 11:26 AM
Hey folks....
I ended up buying Kelford 194-B's. Paid $550 USD for them new back in july of 2010. They are in my engine right now but I'm a bit alarmed. I was told I could use stock valve springs, but I have less than 20 thousandths of clearance between the valve spring at max lift! (.508mm) Do you guys think that is cutting too close? I havent even run the engine to see if VVT will work.... |
06-27-2011, 01:25 PM
Hi grant.
Just wondering how you went with these cams. Steve Steve.....this is sparrrrrtan |
11-19-2015, 07:45 AM
do i need pistons for a stock valve with a 10 mm lift cam and stock profile spring ?
| Kelford vs Toda | Gates Racing vs Toda for 16v | mister86 | 2 | 5,310 |
06-10-2020 04:43 PM Last Post: Lykowsky |
| Shim size for AM cams | kazi | 4 | 7,079 |
| Toda Cams | Alex170984 | 7 | 11,063 |
02-11-2017 05:50 PM Last Post: Alex170984 |
| cams cams cams | megabob | 60 | 71,768 |
12-31-2013 01:19 AM Last Post: gze spec |
| part numbers on standard cams | Alex170984 | 10 | 14,723 |
09-19-2013 02:53 PM Last Post: pack |
