1986 Toyota Corolla Levin 2dr GT-Apex
01-12-2026, 10:11 PM
(01-05-2026 02:41 PM)decryphe Wrote:
(12-30-2025 02:32 PM)livelaughlevin Wrote:  I made a fully upholstered MDF interior for the trunk. It even has a built-in oil bottle holder and hinges for the spare tyre. Sorry for the mess in the picture, it's the only one I have but it should give a good idea of what I did. It is lightweight enough too.
That looks super clean. This is essentially what I would want as well. What did you use to attach the MDF on the sides? It's kind of bare without any screw holes/brackets.
Is that a floor mat on the right side wall?
I saw a nice hole a big bolt could fit through, even though the fit is so tight it is probably not even necessary (said hole is on both sides too!). I have a fire extinguisher bolted to the MDF sides and it is rock solid. The floor mat looking thing is probably the little door I made so I can access the pocket behind it (I have high vis jackets and a blanket stuffed in there in case my fuel pump goes again).
01-19-2026, 01:07 PM
so I finally got an Irish registration plate - and as we start car registrations in Ireland with the year of manufacture, mine begins with 86.
In other news there is a blow in the exhaust on the flexi part of the RS*R manifold, so I'm going to cut out the old flexi and replace with an aftermarket one. I think in future I will go for a Fujitsubo manifold though.
2 new discoveries :
-What looks to be fairly new, SARD sport catalytic convertor fitted after the RS*R
-LSD looks to be installed, as both wheels rotate together in same direction when off the ground.
01-19-2026, 11:03 PM (This post was last modified: 01-19-2026 11:04 PM by banpei.)
(01-19-2026 01:07 PM)ondafly Wrote:  2 new discoveries :
Congratulations on the 86-plate! Hurray!
About the SARD catalytic converter, it's a must if your car is lowered. Even on my non-lowered car I had the cat hit a curb when I was parking carefully on a (not so high) curb. At first, I thought I had hit on one of the frame rails, but actually, it was the cat that got the scrape. And also, it must be beneficial if your whole exhaust system is high performance, as the original is much smaller in diameter.
[Image: AEU86 AE86 - 1986 Toyota Corolla Levin 2dr GT-Apex]
Yesterday, 11:05 AM
good to know. As it stands, its far too low for my taste, although it actually hasn't scrapped anywhere - I like to see the top of the tyre, so it is on the list to raise it up !
Yesterday, 11:36 AM
Doesn't look that low to be honest Smile Getting some A3A's in 14" instead of raising it!
Yesterday, 01:47 PM
Wink 1986 Toyota Corolla Levin 2dr GT-Apex
(Yesterday 11:36 AM)Koen Bongers Wrote:  Doesn't look that low to be honest Smile Getting some A3A's in 14" instead of raising it!
I like your thinking Smile but it feels lower than a go kart right now. I do fancy a nice set of 14" though; but probably Longchamps xr4s
Yesterday, 02:26 PM
Imgur hates me!
Yesterday, 02:42 PM
(Yesterday 02:26 PM)adomz Wrote:  Imgur hates me!
You can send the image to me in a PM and I'll attach it for you.
Yesterday, 05:08 PM
Shameless A3A's in 14" plug.
  1985 Toyota Sprinter Trueno GT APEX kouki from Japan sheppardpat47 8 394 01-19-2026 12:59 PM
Last Post: ondafly
  JDM GT-Apex Trueno in the Alps # decryphe 117 118,640 07-02-2025 12:47 AM
Last Post: decryphe
  Corolla Levin Repair, Paint and Tune - WITH VIDEO apardal 542 713,437 02-16-2024 10:48 PM
  Toyota Corolla AE86 LEVIN ( Poland) sylwekgtir 40 65,193 11-23-2018 10:13 PM
Last Post: sylwekgtir
  Toyota Sprinter AE86 GT-Apex Trueno Skyracer 222 317,444 08-13-2016 12:46 PM
Last Post: Skyracer
