16v distributor hole plug
09-20-2016, 10:39 AM
Spend +2 hours scouting the webs for such a plate... Does nobody make those? I read that a engine block water freeze plug can be used but I'd rather do it properly with an o-ring or some sealant.
- Niels
09-20-2016, 11:42 AM (This post was last modified: 09-20-2016 11:44 AM by demee76.)
http://www.sq-engineering.com/upgrade-pa...e-16v.html
May be a solution?
09-20-2016, 11:51 AM
(09-20-2016 11:42 AM)demee76 Wrote:  http://www.sq-engineering.com/upgrade-pa...e-16v.html
May be a solution?
I know that one, but I want to completely remove the distributor assembly. I am running a crank sensor now.
09-20-2016, 12:28 PM
Do you have access to a CNC, given time I can draw up something in CAD.
AE86 ex-daily
09-21-2016, 11:52 AM
(09-20-2016 12:28 PM)Bean Wrote:  Do you have access to a CNC, given time I can draw up something in CAD.
I know SolidWorks myself, but thanks for offering to help Smile I am just surprised that this isn't in the market...
09-21-2016, 02:29 PM
Considering the fact that changing the cam sensor already involves a bit of custom modifications, I guess the market isn't big enough
AE86 ex-daily
10-10-2016, 10:52 PM
New product from JSP... not yet listed on his webpage
[Image: AEU86 AE86 - 16v distributor hole plug]
Dan -
10-11-2016, 09:59 PM
The cheap option would be a 36mm freeze plug or just a plate with some FIPG.
(I know someone who actually did it with an aluminium plate)
10-12-2016, 11:13 AM (This post was last modified: 10-12-2016 11:15 AM by harkes.)
Nice! Thanks Dan!
And as you say Project D - a plate and some FIPG would do the trick also Smile
  Ignition switch plug and wires Blaze0010 3 3,257 11-25-2024 12:29 PM
Last Post: Blaze0010
  4AGE cylinder head plug removal Ivan141 5 4,954 09-30-2023 09:47 PM
  Plug ID kazi 6 8,895 02-17-2019 10:07 PM
Last Post: kazi
  Anyone know what this plug does? Super86 3 8,382 08-01-2016 03:57 PM
Last Post: Nakilad
  Changing distributor when carb 4age izanagi 14 20,974 07-04-2016 03:27 PM
Last Post: Uzelac
