0-60
12-05-2011, 04:30 PM
Post: #31
0-60
The standard car when new did 0-60 in 8.6 seconds and the quarter mile
in 16.4 seconds at 83 mph. http://retrorides.proboards.com/index.cg...read=49359 An analogue brain in a digital World |
12-05-2011, 05:10 PM
Post: #32
0-60
totta Crolla Wrote:The standard car when new did 0-60 in 8.6 seconds and the quarter mile Just the reason why 7.3 sound insane to me, if only pistons and ECU is changed. It seems to me that that time would be great even for 180+ hp/fully striped AE86 with 4AGE 16V. |
12-05-2011, 05:29 PM
Post: #33
0-60
Uzelac Wrote:totta Crolla Wrote:The standard car when new did 0-60 in 8.6 seconds and the quarter mile You need around 150hp for 14.9 quarter mile AE86. An increase of 30hp over stock is very significant. A wheel to steer the front of the car A pedal to steer the rear |
12-05-2011, 05:45 PM
Post: #34
0-60
NoHachi Wrote:Uzelac Wrote:totta Crolla Wrote:The standard car when new did 0-60 in 8.6 seconds and the quarter mile Quarter mile calculator seems to think it is closer to 170hp with a weight of 1100 kg for 14.9-15 seconds An analogue brain in a digital World |
12-05-2011, 08:18 PM
Post: #35
0-60
No need calculators for AE86, we all know pretty much enough.
150hp and low weight car (drag spec) seems OK for 15 sec mark. But it's hard to imagine stock 4AGE (expect pistons) that can achive 150hp. |
12-11-2011, 08:46 AM
Post: #36
0-60
Road & Track tested the 1985 Corolla GTS and achieved...
1/4 mile @ 18.60 seconds and 79.5 mph. 0-60 mph @ 10.5 seconds, citing axle tramp as being a limiting factor. Car weight as tested @ 2640 lbs (1199 kg). The AE86 was never a hp monster, but could hold its own on the road due to good brakes, factory LSD and decent handling. In Japan it was getting whupped regularly by the Honda CRX 1600, and a little later by the Suzuki Swift GTI 1300. Power to weight is where it's at ![]() Cheers... jondee86 |
12-11-2011, 12:32 PM
Post: #37
0-60
1.2tons? WTF?!
![]() AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
12-11-2011, 12:47 PM
Post: #38
0-60
Curb weight stated @ 1112 kg, so I guess the weight as tested included
for the driver and a bit of test gear. My car (UK spec) weighed 1060 kg without driver, last time I had it on the scales. Cheers... jondee86 |
12-11-2011, 05:47 PM
Post: #39
0-60
10sec is too much.
Descent AE86 can go 8,5-9sec easily with ~ 1100kg, car with two passengers. |
12-11-2011, 08:35 PM
Post: #40
0-60
Uzelac Wrote:BOOMEX Wrote:0-100km/h @ 7.29 Yes the cams are the stock bleutop ones. (240° / 7.5mm lift) The crank and rods were a litel lightened and rebalanced. The head is worked too. It's got a 4in1 Iresa header and a home made 2.244 inch (Ø57mm) over axel cat back Fiber glass boot lid with stock window Sound deader is all removed the cas if fully re-welded with some reinforcement Full interior heater ect.. except the carpet. From a 2nd gear pull i'm with a 170hp civic from 60km/h to 180km/h. ![]() SR Team BURN THE RUBER NOT YOUR SOUL! |
