What spring rate will suit my Konis?
05-02-2008, 10:29 PM
As in title, i desided to buy a pair of the bolt on coilover kit from T3
http://www.technotoytuning.com/productdetail.php?p=278 The thing i dont know is what spring rate should i choose. I use longstroke konis in my hachi, they are in very good condition. The car is a daily driver and occasionaly drift, so im thinking of use stiff springs, ( something like 5-6 Kgs in front) Are konis capable working with that spring rate? Should i have the shock all the way stiff to work ok with the spring? Does anybody uses or used konis longstroke with stiff springs? Impressions? Problems? Anything that could be helpfull... |
| SOME 4AG valve spring specs | oldeskewltoy | 5 | 16,544 |
05-04-2015 01:17 PM Last Post: Project D |
| Tyres to suit new 14" wheels on a daily | Jezza_hr | 4 | 7,997 |
11-04-2014 12:20 PM Last Post: Spitfire |
| clutch pedal return spring | Eifelaner | 2 | 9,245 |
09-06-2013 10:21 AM Last Post: Apsogos |
| Type of carbs to suit 4ag | kpretro84 | 23 | 34,793 |
02-09-2013 02:29 AM Last Post: bakonick |
| P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 4,571 |
04-05-2012 04:17 PM Last Post: Dino86 |
