Tuned 4AGE results
04-02-2009, 12:04 AM
Tuned 4AGE results
Thought this info and result might be useful to others looking to get a certain amount of power frmo a 16v.
11:1 wiseco, narrow port 4age (no porting) IN 272/7.5mm lift EX 272/7.5mm lift Cam timing, Max lift IN@100/EX@98 as per club4ag. Exhaust 4-1 w/2" system. 295cc injectors Silvertop ITB, T3 inlet VEMS 3.3 tuned on dyno. Currently AlphaN from 0-8500rpm. Ideally should be alphaN/Speed density blending. First start: http://s250.photobucket.com/albums/gg269...arting.flv Blue AE86 at the 15second mark is running vems. Fully mapped, it is the car this thread was started for (since resprayed). 15seconds in, LOUD FAST BLUE AE86 http://www.youtube.com/watch?v=uWaPippCz...re=related Another clip of the blue AE86 this thread was started for. http://i250.photobucket.com/player.swf?f...008008.flv Proof of Results and fuel/spark/lambda maps for the benefit of the community ![]() ![]()
04-02-2009, 01:09 AM
Tuned 4AGE results
Hey
Nice looking tests .Question: why did you choose VEMS instead of Megasquirt ? Haven't been really looking, but yours AE86 is first i see with VEMS, and so many are on MS. thanks, regards |
Tuned 4AGE results
My engine: 7 ribbed 40mm crank 81.5 mm toyota pistons Ported bigport head 182CC injectors 260 in 9mm lift (Catcams: 7105137) 252 out 8.5mm lift (Catcams: 7105137) Standard intake with open air filter Standard ECU Super 98 unleaded fuel Stadnard header but cut at the 2-1 juntion to fit a 55mm diameter exhaust under axle. This results into: 134.8 Rwhp and 150.4 NM on the wheels ![]() ![]() On ideal situation I would be running 210CC injectors (which I have laying around) Engine is running a bit lean and I have a power distortion at 7400 rpm Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-02-2009, 01:12 AM
Tuned 4AGE results
Uzelac Wrote:Hey VEMS and OMEX 600 ecu's are really nice. And you don't have to build em. They are used in kitcar build etc Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-02-2009, 01:47 AM
Tuned 4AGE results
![]() please note this is whp Engine model and generation: 4AGE - TVIS head/Silvertop block Top End Modifications: large port head - ported, pinned and port matched intake/TVIS/head, Web 294 cams, AEM camgears(intake advanced 3 degrees), RC 225cc injectors Bottom end modifications: 20V silvertop stock except 16V OEM high compression pistons(10.3 to 1) Management: factory AE86 ECU Fuel used 89+ (USA) Intake: K&N FIPK Exhaust: KBD header, Fujitsubo LegalisR large muffler twintip Driveline: Silvertop flywheel OEM AE92 disc and pressure plate Other Info The above dyno run was done with a tired 20 year old fuel pump! Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
04-02-2009, 01:54 AM
Tuned 4AGE results
robokill Wrote:VEMS and OMEX 600 ecu's are really nice. And you don't have to build em. They are used in kitcar build etc Builiding is not that big issue, beside you can buy it assembled. That cost more but MS is beside VEMS (as much as i know) cheapest ECU. OMEX 600 is near, but still more expensive. I am aware of much better and more expensive standalone ECU's (MOTEC, NIRA...) but i intentionally asked about VEMS and MS since these are (beside carbs ) cheapest options.So, at least from me, question stay: why VEMS and not MS ? |
04-03-2009, 09:48 AM
Tuned 4AGE results
PhatBob lives near me and answered all my questions about EMS.
No tuner, not other ecu manufacturer ever answered questions on how ecus work, or whether it would work as part of a plug and play system. Something I was keen to setup for Irish AE86 owners. I asked Bob try out a plug and play loom on vems several years ago. ![]() It was successful but showed problems in stock AE86 wiring. Helped me understand the benefits of crank trigger, good earths, shielding etc after looking at signals on a scope trace. I am happy to buy from Bob as hes honest and the technology is proven. I like how VEMS Maps the engine VE, showing you what its doing. Lots of reasons, but Im at work and dont have time to type VEMS works! |
04-03-2009, 09:56 AM
Tuned 4AGE results
robokill Wrote:134.8 Rwhp and 150.4 NM on the wheels Smile 150.4NM = 110 ft lb yes? @20% transmission loss ~169.7hp @ flywheel ~137ftlb TQ @ flywheel @25% transmission loss ~180hp @ flywheel ~146ftlb TQ @ flywheel I doubt without awesome headwork, blueprint and balance you will see ~140ft lb TQ! So 169hp/137tq @ flywheel seems right |
04-03-2009, 09:57 AM
Tuned 4AGE results
HP in dyno posted is est flywheel hp.
ECU was tuned on the dyno! |
04-03-2009, 10:14 AM
Tuned 4AGE results
Very good results mates!!!
More more tuning and dyno!!! **COROLLA EE80 - 4AGE 124HP**
| Max a 16v 4AGE can be tuned to? | heshan | 20 | 65,187 |
04-21-2009 08:31 PM Last Post: banpei |
| Silvertop burning oil - compression results | Jezza_hr | 3 | 6,138 |
10-18-2008 02:51 AM Last Post: jondee86 |
| AE86 Dyno Results! | Wraith | 9 | 17,585 |
10-16-2006 09:13 AM Last Post: Mux213 |
![AEU86 AE86 - Tuned 4AGE results [Image: AEU86 AE86 - Tuned 4AGE results]](http://i250.photobucket.com/albums/gg269/twincamdan/DYNO%20SHEETS/JOCTQvsRPMBINS.jpg)
![AEU86 AE86 - Tuned 4AGE results [Image: AEU86 AE86 - Tuned 4AGE results]](http://i250.photobucket.com/albums/gg269/twincamdan/DYNO%20SHEETS/JOCHPvsRPMBINS.jpg)
![AEU86 AE86 - Tuned 4AGE results [Image: AEU86 AE86 - Tuned 4AGE results]](https://www.aeu86.org/download/dyno-graph/id/8785.jpg)
![AEU86 AE86 - Tuned 4AGE results [Image: AEU86 AE86 - Tuned 4AGE results]](http://i79.photobucket.com/albums/j143/oldeskewltoy/DansdynoOct2006adjusted2scale.jpg)
![AEU86 AE86 - Tuned 4AGE results [Image: AEU86 AE86 - Tuned 4AGE results]](http://www.phattransmissions.com/VEMSWB/PlugNPlay.jpg)
