Megasquirt I v3.0 and toyota distributor/igniter
06-03-2009, 12:17 PM
Hi
I need some advise on how to control my iginition using MSI v3.0 and standard igniter/distributor. Let me say that electronics are NOT some thing I know a lot about so PLEASE do not use any slang or abreviations when answering - thanks. If some one could draw a wiring diagram I would be thrilled - Niels |
06-08-2009, 09:04 PM
Hey
If you check the Msmanual forums this has already been up to discussion and im sure you are able to find a wiring schematic there. what you need is to get the trigger wheel inside the distributor wired up to the MS unit. That would solve your question. Good luck. Kp62 - 135hp Ae86 - 135hp C32 Laurel - 440hp C32 Laurel - 125hp
06-08-2009, 11:11 PM
| Megasquirt I v3.0 and toyota distributor/igniter | |||
06-25-2009, 11:07 PM
Hi
No not the same. They (gon) used a VAST (AFM) igniter - mine is a ESA (MAP). I have RPM signal to the MS from the VR sensor to "tach" input (using the VR-sensor circuit). NOT using the Igniter to condition the signal! What I need is to know is which wire (color) is IGT, IGF and NE? - Thanks, Niels |
09-10-2009, 03:02 AM
Is there some news for this Topic...?
Doease you'r MS1V3 is runing? thanks
SR Team BURN THE RUBER NOT YOUR SOUL! |
09-11-2009, 12:18 AM
This is how I did it on the 4age for my KP61 I'm building right now running MS1. Have a bit to go before attempting startup yet, but can not see any reason why it should not work. MS should read it as a 12-1 crank VR setup.
Stock dizzy: [img name=]http://www.aeu86.org/files/ds/dsc00657_medium_102.jpg[/img] Dismantled it: [img name=]http://www.aeu86.org/files/ds/dsc00659_medium_545.jpg[/img] Ground down two opposite tooths (dont recall which ones, but can check if needed): [img name=]http://www.aeu86.org/files/ds/dsc00660_medium_661.jpg[/img] And remounted. Also removed second VR sensor to minimize chance for crosstalk, as it should not be needed for MS and batchfire. [img name=]http://www.aeu86.org/files/ds/dsc00661_medium_108.jpg[/img] '85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21 |
09-11-2009, 12:22 AM
harkes Wrote:Hi Are you using dual VR input and both sensors in the dizzy? '85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21 |
09-11-2009, 01:05 AM
it should work with the 12-1....
I tried with the MS I v2.2 and an LM1815 signal conditioner and I got RPM spikes at around 7000RPM that I couldn't get rid of. That's why I changed to the VAST igniter...... Maybe it will work better with the v3 signal conditioner instead of the LM1815..... |
09-13-2009, 10:15 PM
thanks for the Update
09-17-2009, 05:49 AM
gon Wrote:it should work with the 12-1.... I'm pretty sure the 2.89 code clears up the VR signal spikes are higher rpms. There's a post giving details in the ms general forum. msefi.com Mines set up with as above, but I'm having serious comm issues and my trigger +/- is giving me the shits, rejecting ignition events. |
| How to test coil with igniter | DJexor | 2 | 10,116 |
03-22-2018 10:01 AM Last Post: Project D |
| 16v distributor hole plug | harkes | 8 | 12,201 |
10-12-2016 11:13 AM Last Post: harkes |
| Changing distributor when carb 4age | izanagi | 14 | 20,794 |
07-04-2016 03:27 PM Last Post: Uzelac |
| 4age igniter question! | Ghetto | 1 | 6,240 |
01-09-2015 11:30 PM Last Post: Uzelac |
| Distributor position and cranking | pack | 13 | 24,646 |
07-01-2013 11:08 PM Last Post: pack |
