Factory Electrical wiring diagrams & engine diagnosis ma
Goto page 1, 2  Next
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
parrot
Takumi
PostPosted: Fri Jan 12, 2007 2:12 am    Post subject: Factory Electrical wiring diagrams & engine diagnosis ma Reply with quote
I have scanned up the AE86 factory detailed Electrical Wiring Diagrams Book (1983) as well as the factory 4AGE TCCS Diagnosis Manual. Both have been my bibles for the last few years. Very useful.
Both are on this site in PDF
see below, now on aeu86.org server
The EWD is very detailed and contains each seperate circuit and illustrates each plug and where each wire goes within it. Not just the basic schematic diagrams, though they are there too. Engine diagnosis manual takes you through step by step for ECU and wiring related faults. Includes pinouts. This applies to AA and AE body series with 4AGE
Edit:
AE86 Wiring Diagrams EU/AU (1983) by Parrot (5Mb):
AE86 Wiring Diagrams (EU/AU)
AE86 Wiring Diagrams USDM (1986) by Parrot (5Mb):
AE86 Wiring Diagrams (USDM)
4A-GE Diagnostics Manual by Parrot (8Mb):
Back to top
pedro-siR
Ryousuke
PostPosted: Fri Jan 12, 2007 2:39 am    Post subject: Reply with quote
it has tons of info. too bad it doesn't have the electric window diagrams because is for 1983...
those i needed Stupid
_________________
Pedro Velado
GT-S Owner
Back to top
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
parrot
Takumi
PostPosted: Fri Jan 12, 2007 2:47 am    Post subject: Reply with quote
No problem, I have those too, BUT for the USDM model. The US looms are very different from the Euro looms however I expect the power window section would not vary much until it gets to the junction box. Though actually I note you are in Central America which I presume have LHD US spec GTS's.
I do not have this electronically and it was difficult enough getting access to a scanner to do these two files.
If you PM me either a fax number or an address I can send them to you on Sunday morning Australian time
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Fri Jan 12, 2007 6:22 pm    Post subject: Reply with quote
Parrot: Is it okay if we mirror the diagrams? Puh
_________________
Back to top
View user's profile Send private message Visit poster's website Follow me at Twitter Yahoo Messenger MSN Messenger Skype Name
pedro-siR
Ryousuke
PostPosted: Fri Jan 12, 2007 7:15 pm    Post subject: Reply with quote
Yes parrot, i drive a USDM LHD corolla.
Please mail the diagrams to pedrovelado@navegante.com.sv . Thank you so much, I really appreciate it since I'm having problems with my passenger side window, I cannot open it, unless i take off the door panel and do it manually Mad
_________________
Pedro Velado
GT-S Owner
Back to top
parrot
Takumi
PostPosted: Sat Jan 13, 2007 8:35 am    Post subject: Reply with quote
Banpei - absolutely. I shall try and put up the USDM EWD and other assorted useful things at some stage. Scanning is not so easy unfortunately but I am working on a way around that.
Pedro - if you want it emailed you may have to wait a while as it isn't scanned. I shall see how I go. I can post or fax though.
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sat Jan 13, 2007 1:18 pm    Post subject: Reply with quote
I know the problem. I promised I would scan my EWD as well some time ago, but I never found the time to do it. Neutral
But I've put them up here:
http://files.aeu86.org/manuals/ewd-ae86-1983-eu_au-parrot.pdf
http://files.aeu86.org/manuals/4age-diagnosis_manual-parrot.pdf
As you can see I've put your name in it. Smile
Thanks again! Thumbsup
Edit: I've also added them to our Technical FAQ section. Smile http://www.aeu86.org/viewtopic.php?p=35506#35506
_________________
Back to top
parrot
Takumi
PostPosted: Sun Jan 14, 2007 1:10 am    Post subject: Reply with quote
I'm famous!! Thanks Banpei.
Have just finished copying the USDM EWD too. It has all sorts of odd things such as the trueno pop up light circuit, cruise control, power mirrors, power windows etc.
I shall try and get this scanned on Tuesday and advise when it is up.
Back to top
SutteR
Takumi
1987 Toyota Corolla AE86 (late US)
PostPosted: Sun Jan 14, 2007 2:14 am    Post subject: Reply with quote
Hopefully it contains the power sunroof circuit as well. It's not that difficult but I want to check myself if I discovered the wires correctly... Smile
_________________
1987 Toyota Corolla GT coupe - for holidays oversteer
1999 Toyota Corolla - for daily understeer
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Skype Name
parrot
Takumi
PostPosted: Sun Jan 14, 2007 12:05 pm    Post subject: Reply with quote
The sunroof circuit is in the Euro version already listed above. Not hard, it goes from the junction box in the drivers footwell.
Back to top
SutteR
Takumi
PostPosted: Sun Jan 14, 2007 12:07 pm    Post subject: Reply with quote
OK it's only that I have an USDM version SR5 converted to a Euro style GT. So the wiring is quite interesting but not that mess...
_________________
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sun Jan 14, 2007 12:24 pm    Post subject: Reply with quote
Haha... I think we both have the same problem. Puh
But I thoughtyou converted the front also to Levin, isn't it? Confused
_________________
Back to top
SutteR
Takumi
PostPosted: Sun Jan 14, 2007 6:20 pm    Post subject: Reply with quote
I didn't but the previous owner did. And for more mess the donor GT car was a hatchback so the chassis(?) loom has all the needed wires but mostly with the wrong plugs.
_________________
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sun Jan 14, 2007 8:42 pm    Post subject: Reply with quote
Argh. That's even worse! Mad
Only problem I currently have is the connector of the power mirrors not being the same: probably euro levin has a different connector than the USDM connector... It is something I need to sort out for the past year. Neutral
_________________
Back to top
SutteR
Takumi
PostPosted: Sun Jan 14, 2007 10:00 pm    Post subject: Reply with quote
Sooo you have power mirros? Laaazy guuy... Smile
_________________
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Mon Jan 15, 2007 11:21 am    Post subject: Reply with quote
Real unpowered mirrors. Puh
If I want to change the setting on my right mirror I have to ask my girlfriend to wind down the window and push the mirror by hand. Very Happy
_________________
Back to top
SutteR
Takumi
PostPosted: Mon Jan 15, 2007 1:59 pm    Post subject: Reply with quote
So you can't just drive away for a few hours to be alone with the road and the mountains...oops sorry, you don't even have mountains. Smile It's not that Hungary would have so much of them but we have, and you've missed it in December. Smile
_________________
Back to top
mrgud
Takumi
PostPosted: Mon Jan 15, 2007 5:28 pm    Post subject: Reply with quote
These were verry heplfull... thanx man!! Wink
It takes a few seconds to get the hang of it, but after that a 8year old can figure it out
_________________
SNO-MO-BIRU project started- CHIRO
Back to top
parrot
Takumi
PostPosted: Fri Feb 16, 2007 6:31 am    Post subject: Reply with quote
Pedro-siR you have email
SutteR you have a PM and email, actually your hotmail email bounced. Let me know if the PM doesn't come thru and perhaps a different email?
Back to top
SutteR
Takumi
PostPosted: Fri Feb 16, 2007 4:31 pm    Post subject: Reply with quote
Hi parrot, got and replied your PM. Don't use my hotmail address. Smile
_________________
Back to top
parrot
Takumi
PostPosted: Fri Mar 09, 2007 8:28 am    Post subject: Reply with quote
Have finally got around to scanning the USDM 1986 EWD book. It is 5mb in PDF. Banpei, I shall try to email it to you.
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Fri Mar 09, 2007 6:21 pm    Post subject: Reply with quote
Yep. Pm-ed you my emailaddress. Smile
_________________
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Mon Mar 12, 2007 2:25 pm    Post subject: Reply with quote
Uploaded the usdm ewd:
Thanks! Worship
_________________
Back to top
domi
Ryousuke
PostPosted: Tue Mar 13, 2007 11:40 am    Post subject: Reply with quote
You guys are the best. That could not have come at a better time!
Thumbsup
Back to top
parrot
Takumi
PostPosted: Tue Mar 13, 2007 3:07 pm    Post subject: Reply with quote
Excellent, www at its best.
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
