Gtsi-R red'n black coupé
10-03-2008, 04:05 PM
Post: #91
it's probably the seal between rear pannel and rear light, just bosh some silicone between the 2 and put light back on Tongue
10-03-2008, 04:13 PM
Post: #92
The Doctor Wrote:it's probably the seal between rear pannel and rear light, just bosh some silicone between the 2 and put light back on Tongue
The cheapest, quickest and easiest way to go! Thumbs up!
JapanPower
UoP Racing website
UoP Racing videos
10-04-2008, 09:53 AM
Post: #93
I thought of that too... but i want to remove it sometime Wink to repaint the darn thing...
Gtsi-R
"Trust me, I was an engineer"
10-04-2008, 11:41 AM
Post: #94
We still have a full set for those available in the shop. Wink
[Image: AEU86 AE86 - Gtsi-R red'n black coupé]
10-04-2008, 12:50 PM
Post: #95
owkee thanx banpai, I will check the car i a new gasket will do good, not that the problem is rust or so... and a new gasket will not help..
that would be a waste of money !
Gtsi-R
10-04-2008, 04:07 PM
Post: #96
I have a rust hole so it also rains in my trunk. Blush Sad
ハチロク
11-01-2008, 02:48 PM
Post: #97
Hmm.. new gaskets mounted.. pics up soon.. but water still enters the trunk.. Probarbly the big trunk sealing in cobination with the flange...
But my newest concerns are my rear wheel bearings.. the have got to be replaced before 14Jan, (APK)
Can not do it myself, they are pressed on the axle.. and fckng expensive € 260,- per side :O ex mounting....
and my clutch master cilinder is leaking...
but do I have to completly replace it or renew it ?? what is the bst option?
hmmm expensive month... verry expensive..
Gtsi-R
11-01-2008, 05:44 PM
Post: #98
I think there are rebuild kits for clutch master cilinders. Toyota probably has one. There might be cheap imitiation ones available as well.
11-01-2008, 10:44 PM
Post: #99
I got my slave cylinder through Autopartsonline.nl and I thought they did sell the master as well...
You really need to replace it: it leaks brake fluid on the floor now which will strip off the paint on your floor. So it will be very rustprone then. Wink
11-03-2008, 04:58 PM
Post: #100
I will check autoparts online then!!
Thanx art!
Gtsi-R
  Ivan's coupe: seeing RED Ivan141 688 1,285,122 09-14-2026 02:15 PM
Last Post: Koen
  Corolla GT Coupe - Royalty Black pack 273 355,054 09-08-2026 05:19 PM
  Red over Black UK Ae86 RobH69 5 20,276 02-03-2011 02:01 PM
  my 1984 red over black corolla gt davegtcoupe 3 12,675 10-12-2010 08:14 PM
Last Post: davegtcoupe
  RaceMinded satin black Toyota Corolla AE86 Levin Coupe RaceMinded 22 40,542 09-02-2010 07:25 PM
Last Post: Apolan
