Gtsi-R red'n black coupé
10-03-2008, 04:05 PM
Post: #91
it's probably the seal between rear pannel and rear light, just bosh some silicone between the 2 and put light back on
10-03-2008, 04:13 PM
Post: #92
The Doctor Wrote:it's probably the seal between rear pannel and rear light, just bosh some silicone between the 2 and put light back on The cheapest, quickest and easiest way to go! JapanPower UoP Racing website UoP Racing videos Racing, because football, basketball, tennis & golf only require ONE ball.... |
10-04-2008, 09:53 AM
Post: #93
The Doctor Wrote:it's probably the seal between rear pannel and rear light, just bosh some silicone between the 2 and put light back on I thought of that too... but i want to remove it sometime to repaint the darn thing...
10-04-2008, 11:41 AM
Post: #94
We still have a full set for those available in the shop.
10-04-2008, 12:50 PM
Post: #95
owkee thanx banpai, I will check the car i a new gasket will do good, not that the problem is rust or so... and a new gasket will not help..
that would be a waste of money ! Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
10-04-2008, 04:07 PM
Post: #96
I have a rust hole so it also rains in my trunk.
ハチロク
11-01-2008, 02:48 PM
Post: #97
Hmm.. new gaskets mounted.. pics up soon.. but water still enters the trunk.. Probarbly the big trunk sealing in cobination with the flange...
But my newest concerns are my rear wheel bearings.. the have got to be replaced before 14Jan, (APK) Can not do it myself, they are pressed on the axle.. and fckng expensive € 260,- per side :O ex mounting.... and my clutch master cilinder is leaking... but do I have to completly replace it or renew it ?? what is the bst option? hmmm expensive month... verry expensive.. Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
11-01-2008, 05:44 PM
Post: #98
I think there are rebuild kits for clutch master cilinders. Toyota probably has one. There might be cheap imitiation ones available as well.
11-01-2008, 10:44 PM
Post: #99
I got my slave cylinder through Autopartsonline.nl and I thought they did sell the master as well...
You really need to replace it: it leaks brake fluid on the floor now which will strip off the paint on your floor. So it will be very rustprone then.
11-03-2008, 04:58 PM
Post: #100
I will check autoparts online then!!
Thanx art! Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
| Ivan's coupe: seeing RED | Ivan141 | 684 | 1,257,497 |
08-25-2026 12:02 PM Last Post: cannabolic |
| Corolla GT Coupe - Royalty Black | pack | 271 | 348,648 |
08-06-2026 02:12 PM Last Post: pack |
| Red over Black UK Ae86 | RobH69 | 5 | 20,108 |
02-03-2011 02:01 PM Last Post: Bean |
| my 1984 red over black corolla gt | davegtcoupe | 3 | 12,571 |
10-12-2010 08:14 PM Last Post: davegtcoupe |
| RaceMinded satin black Toyota Corolla AE86 Levin Coupe | RaceMinded | 22 | 40,038 |
![AEU86 AE86 - Gtsi-R red'n black coupé [Image: AEU86 AE86 - Gtsi-R red'n black coupé]](https://www.aeu86.org/sticker-banner-468.gif)
