power steering yes or no...?
09-28-2008, 09:31 AM
Ozone Wrote:Akina, you need to use a non-PS column with a non-PS rack.
Otherwise you will have to make up some sort of extension for the PS column to fit to the non-PS rack.
FYI: the intermediate steering shaft (removable part that comes out of the steering column - has the splines the u-joint slips onto) from an MKIII supra (87-92) will slip right into the corolla P/S column & connect the manual steering rack to the p/s column.
Andrew
09-28-2008, 09:44 AM
topi Wrote:I have a non PAS levin, with wide wheels and lots of camber. I'm a
small guy with little arms... and don't have a problem haha. People
need to consume more energy drinks before they drive.
Yeah... wide tyres are really only a problem when parking, or making
similar walking pace manouvers. Even with standard width tyres on a
non-power steering car, you soon learn to turn the wheel while the car is
moving. Once you have some speed up, the problem disappears Smile
The upside (IMHO) is that you get a better feedback from the front
wheels without P/S getting in the way.
Cheers... jondee86
09-30-2008, 08:56 PM
W\ell done)thanx for All
Rising Sun T
10-01-2008, 12:16 AM
Cheers... jondee86
Quoted for truth. After driving around for a few days without power steering, I can easily say that the feedback you get is far more noticeable (this is not the first time i've driven an 86 without ps) without it. The downside to it however is you cant steer as quickly, so flicking out the tail end of the car is a little bit more work and a struggle to some.
I'm toying with the idea of putting it back on, simply because i'm used to the power steering now and I do a lot of parallel parking and street driving. One thing I did ask in another thread is if it's damaging to the PS rack if it has no fluid in it - e.g does the fluid lubricate anything that could get wear and tear if it's not lubricated?
10-01-2008, 01:48 AM
for maximum comfort use powersteering
for maximum controll don't,
same rules apply for the brake booster
3x ke70, 2x te71, 2x ae86, 1x ke20 and 1x hilux
  idler pulley for 4AGE with power steering/aircon ondafly 4 452 07-06-2026 11:11 PM
Last Post: ondafly
  Power Steering Removal 20valver 2 2,787 05-19-2024 06:48 PM
Last Post: 20valver
  Power steering clunk Jezza_hr 12 19,751 09-24-2021 01:42 PM
Last Post: pack
  Why Manual Steering Rack ?? Power Steering Removal juantonwan 26 53,460 10-02-2014 06:07 PM
  AE86 non-power steering problem andee17 3 9,208 07-25-2013 06:41 AM
Last Post: jondee86
