Cams /w 9+mm Lift
08-25-2008, 08:15 PM
Cams /w 9+mm Lift
Hi,
Where can I find Hi-lift cams (9mm+) for the 16V engine? Duration about 260-270° (a little more aggressive than the KK101 from Ted Components) -> What about Toda cams? 264/272° @ 9/10mm
Are Toda valve springs ok for >9mm lift? Combined with 1SZ-FE buckets
Thanks,
Patrick
08-25-2008, 09:25 PM
Cams /w 9+mm Lift
toda says that their valve springs are o.k. up to 10.5mm lift.
go-go-go!
08-26-2008, 12:41 PM
Cams /w 9+mm Lift
ok, that's already useful info, thanks!
08-27-2008, 05:31 AM
Cams /w 9+mm Lift
That is a good amount of lift, you might need under bucket shims.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
08-27-2008, 08:14 AM
Cams /w 9+mm Lift
Well, thats what I wrote.... Blush Banging head Wave
08-27-2008, 09:14 PM
Cams /w 9+mm Lift
CAT CAMS
Here:
http://www.catcams.be/800x600/mainframe.htm?english
and pricing here:
http://www.catcams.co.uk/pricing.asp
09-10-2008, 08:52 AM
Cams /w 9+mm Lift
i ll use 272 and 10,3lift. ll i need shims?
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - Cams /w 9+mm Lift]
09-10-2008, 07:08 PM
Cams /w 9+mm Lift
You should consider TODA cams or HKS cams. They are readily available and have sizes you need.
09-10-2008, 11:29 PM
Cams /w 9+mm Lift
i have bought TODA with that duration and lift
  Shim size for AM cams kazi 4 7,808 12-18-2017 05:34 PM
  Toda Cams Alex170984 7 12,022 02-11-2017 05:50 PM
Last Post: Alex170984
  20V cams - CATCAMS vs KELFORD? Grant 19 47,135 11-19-2015 07:45 AM
Last Post: hachirokkos
  Effects of valve lift - worth it going higher? harkes 18 23,185 03-17-2014 09:21 PM
  Max lift on Vitz valve lifters harkes 9 15,102 01-02-2014 10:27 AM
