Voltage to the Coil should be?
08-21-2008, 10:11 PM
Hi guys,
When I have the key in ON position:
Voltage across the coil is 4.2 V
When I press key into START position and engine crank:
Voltage across coil is 3.4 V
However, the Spark Plugs don't seem to be firing. Any idea on what we can do?
08-22-2008, 11:36 AM
With the key on, there should be battery voltage at the coil positive
terminal. This is measured between the coil terminal and chassis
(ground).
The coil resistance (measured with all wires disconnected) should
be about 0.5 Ohms on the primary side (+ve to -ve terminals) and
between 10-15 kOhms on the secondary side (+ve to high tension
terminals).
Cheers... jondee86
08-27-2008, 05:33 AM
For the coil, please make sure that the grounds on the ignitor are clean and are connected to a clean ground.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Coil charge time totta Crolla 0 780 01-23-2026 07:27 AM
Last Post: totta Crolla
  Smallport coil totta Crolla 2 3,776 08-12-2022 11:03 AM
  How to test coil with igniter DJexor 2 10,527 03-22-2018 10:01 AM
Last Post: Project D
  Injector voltage problem [fixed] d3nso 16 24,418 04-03-2016 12:39 PM
Last Post: d3nso
  How far should I have to push my clutch in dinkers542 4 8,568 11-29-2014 11:18 PM
Last Post: dinkers542
