Fuel pump and starter on the same relay
08-19-2008, 09:23 AM
hi
can i connect the fuel Pump and starter to one 5 pin relay switch 85 ground 86 ignition 87 battery 30 fuel pump and starter |
08-19-2008, 11:09 AM
If the "starter" wire energises the starter solenoid, it won't work.
If the "starter" wire leads to a second set of contacts that close to energise the starter solenoid, then yes, it will work For example. the second set of contacts could be a momentary contact "start" push button, or the "start" contacts on the ignition keyswitch. Cheers... jondee86 |
09-03-2008, 05:40 AM
The starter and fuel are not on the same relay, but on seperate circuits turned on in unison.
09-03-2008, 07:10 AM
Search for parrots post with links to the Electrical Wiring Diagrams. Everyone who even looks sideways at their wiring should have one of these open next to them!
| 20v BT - which oil pump? | Mylesmck | 4 | 5,680 |
| Fuel pump issue | DJexor | 11 | 10,865 |
| AE86 starter options | max_ae86 | 12 | 37,958 |
07-28-2019 08:17 PM Last Post: harkes |
| Trunk and fuel door cable | pack | 2 | 9,497 |
04-23-2018 11:01 PM Last Post: pack |
| fuel line hose from the pump | Wikizz | 4 | 8,315 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
For example.
