Ian.G's Track/Drift Levin.
07-13-2008, 05:53 AM
Post: #341
Ooohh! Porn!!!
Good to see it take shape Ian. There's some people who think it's better not to have a strut brace anyways, in case you'd ever hit one corner, in which case you'd only have one side to repair... It's probably strengthened enough anyways. Looks like you're preparing to complete some sort of air box - Not leaving it on open throttles then? Anyways, looking forward to seeing it up and running. Looks like you're going to be busy on the run up to Xmas! VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
07-15-2008, 08:33 AM
Post: #342
Looks better and better! The airbox backplate would look much better in carbon/kevlar though, because it would mach the valve cover... OMG, what I'm saying? PORN!!!
07-29-2008, 11:02 AM
Post: #343
The Rad is mounted
![]() ![]() The front panel has been cut out and replaced with a bolt in carrier for the rad. This makes it much easier to get the engine out as you just pull the rad out and come straight through the front of the car. The header tank will be getting done next along with all the water lines. The exhaust system should also be completed this week. Regards Ian. |
07-29-2008, 11:10 AM
Post: #344
It always makes me happy when i see this project moving on
08-06-2008, 11:27 PM
Post: #345
my buddy loaned me an ITG filter to try out for size.
![]() hmmmm... it no fit. ![]() I now have a smaller one which I'll take down soon. The bits of the water system are all sorted now. The rad has had a small -3 takeoff welded onto it, the alu water lines are done. I was considering using wiggens connectors for the lines - but they are just too damn pricey for now LOL. Just regular silicone humps as joiners will be fine. Header tank is also sorted. -3 and -8 braided lines for the smaller pipework. ![]() RS started tagging the manifold together so they could get all the runner lengths right. ![]() ![]() Bit more done at the manifold ![]() Just needs the last collector putting in now and its finished. ![]() Loads and loads of space between the manifold and the brake cylinders too which is nice. ![]() Water lines are all in place too so the water system is finished bar a few of the smaller -6 lines that run to the other side of the engine. ![]() I feel all happy about my car - more so than I have done in a long time
Regards Ian. |
08-07-2008, 08:42 AM
Post: #346
Probably because it is so beautiful and so rad!
08-07-2008, 08:51 AM
Post: #347
Goddammit Ian this is pure porn!!
Nice weldings on the manifold 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
08-07-2008, 01:32 PM
Post: #348
Ian, manifold looks stunning, now get it out of there so they can do mine lol
I'm currently taking HRT ~ Hachi Roku Therapy |
08-07-2008, 02:58 PM
Post: #349
I've never seen a nicer manifold than that!
08-07-2008, 03:10 PM
Post: #350
i got no disc in the back how do i turn it to disc are ther any conversion kits or i just got to get a whole axle
| Track AE86 Build from south america | Nurburgring | 3 | 10,603 |
| Ae86 Levin drift project. | filip.alin | 7 | 13,164 |
| 86er's Track rebuild N2.??? Finally an update page 8 | 86er | 191 | 314,615 |
| (AUS) 8age trueno track monster! | green_boy_91 | 48 | 74,014 |
| KP61: The track fridge | 127 Boy | 20 | 37,978 |
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh3.ggpht.com/theoriginaliangratton/SI2ezaqYf4I/AAAAAAAACcE/8Q4xwJMfHPc/s800/radiator1.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh3.ggpht.com/theoriginaliangratton/SI2eziSLlLI/AAAAAAAACcM/EusbNlQFslY/s800/radiator2.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh6.ggpht.com/theoriginaliangratton/SJSQMnKjK1I/AAAAAAAACd4/1h2UDbQEshY/s800/airbox.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh3.ggpht.com/theoriginaliangratton/SJSTJgcw0zI/AAAAAAAACec/MsehZc8lNyc/s800/airbox2.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh6.ggpht.com/theoriginaliangratton/SJSQDxRaKpI/AAAAAAAACdo/WG20-hghUpY/s800/radiatorlines.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh6.ggpht.com/theoriginaliangratton/SJSQGtEjE8I/AAAAAAAACds/v15NFvd05Hw/s800/manifold.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh5.ggpht.com/theoriginaliangratton/SJSV3YyTciI/AAAAAAAACfA/KZEs4N2z6DU/s800/manifold2.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh6.ggpht.com/theoriginaliangratton/SJl53a4j9SI/AAAAAAAACf0/C4_OSfKLcv8/s800/manifold.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh3.ggpht.com/theoriginaliangratton/SJl53oRH1EI/AAAAAAAACf8/zb7Jm26nGcw/s800/manifold2.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh4.ggpht.com/theoriginaliangratton/SJl6mIxKv0I/AAAAAAAACgg/9rwOwUnTesE/s800/manifoldinenginebay.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://lh5.ggpht.com/theoriginaliangratton/SJl6magunlI/AAAAAAAACgo/0wpgdQAjhw8/s800/waterlines.jpg)
![AEU86 AE86 - Ian.G's Track/Drift Levin. [Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]](https://www.aeu86.org/sticker-banner-468.gif)
