Mocal oil cooler & sandwitch plate ordered
05-09-2008, 08:12 PM
F0Bman Wrote:Thermostatic valve does seem like a great idea, but the more moving partrs the less reliable .
it is just a termostat.. nota moving part... Wink
cheers Roel
I think I will order a kit if I know that the oil cooler is Moscal too... see like it though.
the prices of http://www.biesheuvel.nl are far above this price..
cheers roel
05-09-2008, 08:21 PM
Roel, a thermostat DOES move Tongue
05-10-2008, 10:30 AM
The Doctor Wrote:Roel, a thermostat DOES move Tongue
yeah by wax that is getting hot and expands.. Wink but it is not a critacall part.. that is not exactly wat I call a moving part..
or should I order the part without termostat.. so the oil is allways running trough the oil cooler.. ??
it will save me 20 pound Big Grin
cheers roel
05-10-2008, 11:06 AM
you can always do like i do ...
manual thermostat Tongue
a cardboard is always in front of the oil cooler.
I only remove it on track days
but as in every manual thing you have to keep an eye on the oil temp to know if you need to remove the cardboard or not .....
05-10-2008, 12:44 PM
and what are acceptable oil temps for our 4ages???
05-11-2008, 11:37 AM
aceptable is around the 100 dgs Celsius like anny other cars..
above the 130 dgs most oils lose there function and get thin as water.. there is a castroll RS oil.. but will cost in stead of 6 / 8 L for normal oil 25 euro / L !! verry expensive oil..
05-13-2008, 12:02 PM
owkee.. If the cooler is an Mocal then I will order this Kit! with a 16 row cooler for the cooling cappacity.
Edit:
He has got no more RWD sets in stock... Sad But it is not that divers to a FWD type..
only thing I can come up to is the lengt of the hoses...
Cheers,
Roel
05-13-2008, 03:29 PM
http://www.thinkauto.com
05-13-2008, 05:00 PM
thanx mate!!
will look there !!
05-14-2008, 02:52 AM
If you have a look at my build file, you will see some photos including a remote thermostat
http://www.aeu86.org/viewtopic/parrots-s...highlight=
  Oil cooler totta Crolla 0 2,897 07-25-2021 03:25 PM
Last Post: totta Crolla
  Oil cooler kit izanagi 7 11,605 09-20-2016 11:13 AM
Last Post: harkes
  Permanent oil cooler vs thermostat Lt86 19 27,687 03-28-2015 06:54 PM
Last Post: Lt86
  trans oil, lsd oil change Apolan 9 21,971 10-01-2014 03:57 PM
  Spindle dimensions, backing plate bolt pattern Rascal21 18 29,057 03-13-2014 11:45 AM
Last Post: Rascal21
