broken Crankshaft
05-08-2008, 08:51 PM
broken Crankshaft
Hello ,
A friend of mine broke his crankshaft on a 4AGE . He has a 3 ribs block , and small journals.
He was told that it was a common failure .....
It's a rally car , he doesn't want to have the same bad adventure .
Here's the question : will a big journals crankshaft fit his 3 ribs block .
He will have to change rods to fit journals , but will these big rods fit the forged pistons he have ? Or does he have to change pistons too?
Are the main crankshaft bearing same on both parts ?
and the last one : does somebody has the Toyota part number for the big crankshaft. He asked his local dealer , but he only have the EPC , are there are no measurment on crankshaft
Do you have any replacement suggestion HKS Toda or else ?
I'v added a pic of his car , he's a spectacular rallye driver as you can see
(162HP weber 45 dcoe powered )
any help welcome
Regards
Filh
Filh
Save the RWD cars
05-08-2008, 09:00 PM
broken Crankshaft
In french
Malheureusement pour lui il doit changer tout le bas moteur (bloc/vilbrequin/bielle/piston) pour celui d'un redtop, car rien n'est compatible...
05-08-2008, 09:52 PM
broken Crankshaft
13401-16020
AE86 GTS '84 Red Top
05-08-2008, 10:17 PM
broken Crankshaft
thanks for the part number .
in french :
<<<<D"après les infos que j'ai les paliers de vilebrequins sont les mêmes , seuls mes diamètres de maneton changent .
J'attends la suite<<<
Still waiting your further informations : will he have to change block and pistons, to have the big journals crankshaft ? (It's what he wants to have)
Filh
Filh
Save the RWD cars
05-08-2008, 10:19 PM
broken Crankshaft
Both axles have same main bearing size (48mm) and it fits straight in to 3 rib block.
What size piston pins he have? 18mm? 19mm? 20mm?
Most 42mm conrods have 20mm piston pin. I don´t think that there is a conrods that have 42mm lower hole and 18mm piston pin.
In here are many over 200hp 4A-GE rally engines and almoust all uses original (but balanced) 4A-GE 42mm cranshaft, including me.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
05-09-2008, 07:34 AM
broken Crankshaft
The problem isn't uncommon. Did he balance everything properly?
[Image: AEU86 AE86 - broken Crankshaft]
05-09-2008, 07:44 PM
broken Crankshaft
Tell him to get a billet Formula Atlantic one and call it a day. I have one if he's interested.
F0b
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
05-10-2008, 07:17 PM
broken Crankshaft
Big crank will fit, requires big conrods and pistons.
Hi-rev requires precision balancing.
05-12-2008, 10:24 AM
broken Crankshaft
S.K. Wrote:I don´t think that there is a conrods that have 42mm lower hole and 18mm piston pin.
I actually just discussed this with a fellow Toyota-enthsiast who's building a gr.F AE92 and he suspected that it may be possible that late-model 4A-FE engines could have a 42mm rod bearing and a 18mm interference-fit piston pin. I have absolutely no experience with 4A-FE engines so I can't say anything one way or the other. Anyone know more?
05-12-2008, 11:23 AM
broken Crankshaft
I have changed conrod bearings to one 98-99 Avensis 4A-FE engine, there was 40mm rod bearings... Don't know what size the piston pin was, because I did it under the car.
I take off the sump, change bearings and then put sump back...
  Crankshaft stamping Blaze0010 6 4,279 06-10-2024 10:16 PM
Last Post: Blaze0010
  Which new bearings for ae101 4AGZE crankshaft&connecting ditn 4 9,174 10-31-2013 06:04 PM
Last Post: ditn
  Broken 20v upper timing belt cover chip 2 5,704 07-16-2012 07:11 AM
Last Post: Jan Pedersen
  Broken bolts - Water pump pack 13 18,659 10-05-2011 08:02 PM
Last Post: pack
  changing diff ratio, broken LSD??? fax0815 6 10,190 09-06-2011 08:19 PM
Last Post: fax0815
