REAR END QUESTIONS
05-08-2008, 05:12 AM
REAR END QUESTIONS
i have a 87 ae86. my rear ind is shot. my posi gave out and it whines real bad. fixing it is not a problem. my question is how do i identify what rear end it is. the car was origanly a sr5. but was converted to a gts. i dont know if the rear end was changed or not. what are the best ways to identifing what rear end it is. i am going to rebuild the posi unit and regear it too. ive got 4 11's in it now and it is way to high. no top end. i just need to know what ring gear i need to get.
thanks for all of the help matt |
05-08-2008, 11:20 AM
REAR END QUESTIONS
if its got discs its not the sr5 axle
05-08-2008, 11:37 AM
REAR END QUESTIONS
If it has discs it is propably a the GT one with the LSD. Originally they came with 4.3 ring and pinion ratio but you can also have a 4.77 which is shorter.
Toyota Corolla KE30 + Toyota Corolla AE86 |
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 8,569 |
| Windscreen stoopid(?) questions.... | Mylesmck | 7 | 4,593 |
04-30-2024 09:46 PM Last Post: Mylesmck |
| Brake Bias Questions | mad.matt | 10 | 16,422 |
01-03-2019 04:54 AM Last Post: mad.matt |
| 20v mains & big end bearing | izanagi | 9 | 14,256 |
12-26-2016 12:42 PM Last Post: pack |
| wider rear axle,track width,suspension questions | ditn | 6 | 12,990 |
