| Author |
Message |
NZ Trueno Wataru
Posted: Fri Oct 13, 2006 9:31 am Post subject: |
Oh mate,
It sounds like you and i are in the same boat! I am also a high school student (I dont know how old being in your junior year makes you, but i am 16)
I have a genuine ae85, with a clapped out old 3au engine (1500cc carby). In the last few months in New Zealand i new regulation has been introduced saying that i cannot have visible exhaust smoke for 5 seconds or more. My car will never pass this. I am looking at swapping my 3au for a silvertop (or blacktop if i can afford one) and i assume that my conversion would be very similar to your's. So make sure you get working so i can copy you!
If someone can answer in one post so i dont Hijack this thread too much, the compression in my engine is very healthy and i do not think the piston rings are fried, but it has just recently gone through 3 litres of oil in 2 months without leaking. I know it is burning oil but i dont know how.[/u]
_________________ Past Toyotas:
'84 AE85 Trueno
'90 AE92 Corolla
'86 AW11 MR2 (auto)
Current Cars:
'85 AW11 MR2 - The minter
'86 AE82 FX GT - 3sge coming soon!
ST182 Celica - 3sge donor
'86 L300 Van - on LPG!
| Back to top |
Mux213 Site Admin
Posted: Fri Oct 13, 2006 9:46 am Post subject: |
nztrueno,
Is that a law that they can give you a ticket on when a cop sees you at any given time or just at MOT?
If its just at MOT, make sure you show up with a warm engine:D
_________________ Greetz,
No more hachi
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4682 Location: Netherlands Z-H
Posted: Fri Oct 13, 2006 6:46 pm Post subject: |
Or throw in some heavier oil to stop it from consuming so much of it temporarily.
It probably leaks some oil past the valve seals..
'81 poor guy with a money-pit
| Back to top |
NZ Trueno Wataru
Posted: Sat Oct 14, 2006 9:06 pm Post subject: |
It is both. I am just lucky that no cops have spotted me, or my cloud of white/grey/black smoke (depends on the day) that fills an intersection after i leave it. MMmm I think i will just get a new 3au engine for the meantime. I can get one for about $100.
But no more about my car, this is Evfan's thread.
'84 AE85 Trueno
'90 AE92 Corolla
'86 AW11 MR2 (auto)
Current Cars:
| Back to top |
evfan42 Ryousuke
Joined: 19 Aug 2006 Posts: 169 Location: Westport, Washington
1986 Toyota Corolla AE86 (late US)
Posted: Thu Oct 19, 2006 10:35 pm Post subject: |
I got it started!
but the accelerator pump isn't working and I have flowmaster... I think that i'm gonna put on it.
| Back to top |
evfan42 Ryousuke
Posted: Wed Oct 25, 2006 6:41 am Post subject: |
Just and update, with pics this time...
and for Nohachi, I've dones this in my "four day weekend"
Viewed 2525 Time(s) Click to enlarge
Viewed 145 Time(s)
the cleaned out engine compartment and overhauled engine
Viewed 94 Time(s)
had to fabricate a pushrod for the clutch master cylinder. took the original and welded a piece of all thread to it.
Viewed 102 Time(s)
the instructions I got with the carb rebuild kit
Viewed 129 Time(s)
my dad\'s welds for my muffler... hes just learning and I dont know how to yet.
| Back to top |
Mux213 Site Admin
Posted: Wed Oct 25, 2006 9:19 am Post subject: |
Ah looks like you're on your way to get her running:D
Any ideas yet when you'll be starting on the swap or have you desided to let that rest for awhile?
No more hachi
| Back to top |
evfan42 Ryousuke
Posted: Wed Oct 25, 2006 3:57 pm Post subject: |
Well, after I looked at the vems loom I am thinkning that I am going to go with that, its about 300 dollars, and I can get a silvertop loom for 200, but with the vems loom I dont have to cut into the firewall for the distrubiter, which just makes life that much easier. So first I will have to come up with some money, then I will be able to continue with the swap.
| Back to top |
NoHachi Moderator
Joined: 07 Sep 2004 Posts: 1998 Location: Delft - The Netherlands
Posted: Wed Oct 25, 2006 4:48 pm Post subject: |
Its just 300 for the loom right? Not including the VEMS unit itself...Count on around 1000$ to 1200$ for a complete VEMS setup. Support for the VEMS seems to better in Europe then the US. Consider a MegaSquirt..its less powerfull, but better supported at your end of the pond and a bit cheaper.
_________________ A wheel to steer the front of the car
Scuderia Rollator
| Back to top |
evfan42 Ryousuke
Posted: Tue Nov 07, 2006 7:11 am Post subject: |
Yeah, your right noHachi *meh* oh well that'll be a later project,
But
She runs, and back on the road!
| Back to top |
evfan42 Ryousuke
Posted: Wed Jan 03, 2007 7:36 am Post subject: |
Well it definatly has been a long time since I have posted anything.
but a few things have changed. I have set up a stereo in my car now, Sony Xplod.
As well as I finally got enough money to get a megasquirt system. As soon as I buy it and put it together, test it, all that good stuff Im pulling my 86 in to do an engine swap.
Viewed 96 Time(s)
Sony xplod
| Back to top |
evfan42 Ryousuke
| Back to top |
evfan42 Ryousuke
Posted: Fri Jan 26, 2007 8:26 am Post subject: |
Is anyone going to answer??? or have you all figured this thread dead?
| Back to top |
Mux213 Site Admin
Posted: Fri Jan 26, 2007 10:06 am Post subject: |
Nah, I think people are just busy atm, its middle of the week you know:D
I have no idea if this is a good fuel pump. Doesn't really list the GT so you may need to do some alterations, then again, having an SR5 fuel tank you prolly need to do that anyways:D
No more hachi
| Back to top |
NoHachi Moderator
Posted: Fri Jan 26, 2007 10:34 am Post subject: |
255hp fuelpump might overpower the stock regulator..that would give you to high fuel pressure..I'm not 100% sure, so its worth researching..
Scuderia Rollator
| Back to top |
evfan42 Ryousuke
Posted: Tue May 08, 2007 8:15 am Post subject: |
Well, im bringing up my very old topic, but not much I have done for the swap except saving money, but I have managed to get some corner lights from a guy who also owns an 86 in the same town that I live in, we met my coincidence.
| Back to top |
evfan42 Ryousuke
Posted: Mon Jul 30, 2007 10:38 pm Post subject: |
alright well long time no talk but im ready to get moving shortly...
I have some bondo.... ordering some paint.... and I have a professional bodywork and painter from the westport shipyard (no 7 yacht builder in the world ) to help me. He also happens to have a corolla as well that hes working on so we agreed to help each other in a scratch my back ill scratch yours way..
pics soon but its gonna really sweet to finally get the body straightened out and re painted a sapphire blue metal flake.
also for the silvertop I have someone who I worked on their truck is probably going to order the megasquirt equipment so that I can work on wiring that up and getting the silvertop into my car.
| Back to top |
evfan42 Ryousuke
Posted: Sat Oct 27, 2007 11:03 pm Post subject: |
So, if you guys are still following this topic, I have taken my SR5 out of my corolla, and have taken the moutns off it...
I have bought, soldered, and tested the megasquirt II system, I also bought Megaveiw, Ford EDIS, and now am getting ready to fix up and paint the corolla the Saphire blue metal flake I have.
Pictures later
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Oct 28, 2007 1:45 pm Post subject: |
You have taken the SR5 out of your SR5? You mean the 4ac?
*** http://shop.aeu86.org - shop at aeu86 dot org - Sint Vitusstraat 78, 1211PK Hilversum, NL ***
| Back to top |
evfan42 Ryousuke
Posted: Mon Oct 29, 2007 6:30 am Post subject: |
| banpei wrote: | You have taken the SR5 out of your SR5? You mean the 4ac?  |
yeah, thats what I meant, lol yeah that worn out engine has been taken out and is being cleaned up.
| Back to top |
evfan42 Ryousuke
Posted: Sun Nov 11, 2007 12:31 am Post subject: |
picture of the silvertop so far
| Back to top |
evfan42 Ryousuke
Posted: Sun Jan 06, 2008 12:53 pm Post subject: |
Just finished rerouting the waterlines inside the silvertop so that I dont have to touch that firewalled when combined with the EDIS system.
| Back to top |
evfan42 Ryousuke
Posted: Wed Apr 30, 2008 1:11 am Post subject: |
well its been forever, time for an update
I've been working pretty hard on this swap, what do you think?
the signatures on the motor are the formula D AE86 drifters
My friend and my dad have been working a lot with me to get this paint job done at the same time
Ridinslideways has hooked me up and did the actual paint shooting and helped a lot with the bodywork
were going to wet sand, buff, polish, and wax it tonite ill post pics when that is finished
| Back to top |
jlrolla
Joined: 17 Jun 2006 Posts: 4 Location: San Antonio TX
Posted: Sat May 31, 2008 1:29 pm Post subject: |
