Velocity Stacks - Which, Where, How much?
04-29-2008, 04:29 PM
I just bought an ITB setup for my engine and I'm looking for velocity stacks for it. Besides T3, which stacks and where can I buy for silvertop?
Are there any carb stacks that can bolt on this setup? They come a lot cheaper than T3, for example, and look the same. I'm just not sure about the size and bolt pattern.
Best regards
04-29-2008, 05:25 PM
I will follow this. i have also silver itb´s and need the stacks:-)
04-29-2008, 05:26 PM
I'll go for these:
[Image: AEU86 AE86 - Velocity Stacks - Which, Where, How much?]
They are €200 for the set...
04-29-2008, 05:27 PM
check here guys.
You need 48 mm diam...
http://www.jenvey.co.uk/
04-29-2008, 05:44 PM
Jan, you just missed the where question!! Cool
By the way, what's the inside diameter of the ST ITB's? I heard it was 43mm... and the BT 45mm...
Not sure though!
04-29-2008, 06:15 PM
48 both.
Inside Diameter,yes.
The diference is on the holes.
for S/T you can use from Peugeot, the holes are the same.
You only have to slighty modify the lip (top end) of the velocity stack, because you are going to have a small contact there....
04-29-2008, 07:41 PM
I've heard that it was 45 and 48 mm Confused
Apardal, well maybe i didn't quite answer you question but unless you are interested in these stacks and are willing to pay €200 for them there isn't much point in telling you where to get them Wink
I can order them here in Denmark if you want them... Here is a link: http://www.sitecenter.dk/sjctoyota/hjemmeside/
04-30-2008, 12:27 PM
Measured them yesterday and the biggest inner diameter at the top is around 46.5mm.
Best regards
04-30-2008, 03:38 PM
apardal Wrote:Measured them yesterday and the biggest inner diameter at the top is around 46.5mm.
Best regards
My measure with Vernier caliper is 47mm
  4age 16v engine which is it ? Apsogos 12 21,314 11-03-2014 12:13 PM
Last Post: Apsogos
  Which Color??? oldeskewltoy 11 16,402 05-27-2014 04:22 AM
Last Post: AlexKTM
  which is the best quality flywheel brand for 4age smallport? LyndonAE86 NZ 8 16,436 12-06-2012 01:20 AM
  How much did you paid for you TOYOTA AE86??? kennedy8383 11 16,176 09-07-2011 09:16 PM
Last Post: fax0815
  How much you recon this rare set SSR CASABLANCA rims worth? FT86 10 19,012 04-29-2011 02:05 PM
Last Post: FT86
