AE86 GTV-Multipoint Cage, Beams, AP Brakes & Brides
04-26-2008, 12:40 AM
Post: #31
Next up.....
the cross member gets a little modification to create more room for the F20C sump. Cut, plated and strengthened.
[Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides]
Off it goes for powder coating to get that new look again Big Grin
I'm currently taking HRT ~ Hachi Roku Therapy Big Grin
04-27-2008, 07:46 AM
Post: #32
How much does it cost for the cross member? It looks like a very well built piece.
04-27-2008, 11:49 AM
Post: #33
hm, this is a common solution for the f20c swap, but is it strong enough?
04-27-2008, 06:51 PM
Post: #34
The cross member is better built now than it was from the factory Wink Much stronger Big Grin
05-10-2008, 01:01 AM
Post: #35
Ok here we go, some pictures of the progress from RS....
Stitch welding of all the front seams for a little bit of added strength.
Next up... tailgate starting to get stripped out prior to removal.
No rust on this one....
Hopefully the cage install will be next Big Grin
05-14-2008, 05:21 AM
Post: #36
Looking good & getting more interesting all the time! Keep us posted Conrad! Cool
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
05-14-2008, 06:43 AM
Post: #37
I am actually in the midst of the same project on a left hand drive version.
I am doing most of the work along with a friend of mine who will do all the welding.
My car will be my daily driver so I am not going as hardcore as you or some of the people who do these swaps are. (I'm pretty young and poor too).
My subframe is already welded and good to go, I am making some 1cm spacers because my cusco mounts are smaller than the stock ones and I am using the JSP mounting kit which was designed for the stock mounts.
I am not lowering the subframe though.
I have cut the tranny tunnel and dropped the engine in for a test fit, everything looks like it will work, but I'll be 100% sure once I have those spacers made and in.
Next thing on my list is to take the motor back out and remove the seam sealer so I can stitch weld the engine bay and paint it black.
How did you removed the seam sealer???
I think I'll make a thread like this once I am done showing my progress.
05-14-2008, 09:28 AM
Post: #38
Square, the seam sealer is removed using a drill and a wire wheel, that gets most of it out then its a case of using a sharp pointed object to get in the nook & cranny's. You'll know if there is still some there as it wont weld Big Grin
Miguel, thanks Big Grin
05-20-2008, 10:28 AM
Post: #39
Well, a few goodies have started to arrive Big Grin
Equal Length 4 link bars.
Tow Hook.
Bottom Arms.
Adjustable Top Mount Camber Plates.
Top Hat Spacers.
[Image: AEU86 AE86 - AE86 GTV-Multipoint Cage, B...mp; Brides][/img]
05-20-2008, 09:45 PM
Post: #40
looks good man. Thumbs up!
i used a turbo torch (acetelyn only) to remove sealer, it got it soft enough to srap w/spatula/scraper.
te72 wagon
ae86 levin coupe project
  ae86 racecar with beams engine bakonick 151 217,246 06-02-2026 10:33 PM
Last Post: bakonick
  Krullibulls Ae86 BEAMS is the only way krullibull 86 126,102 05-07-2019 09:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 929,917 09-03-2017 09:24 PM
  Beams Levin build mannix20vt 5 12,571 01-27-2016 12:39 AM
Last Post: mannix20vt
  Another AE86, Duracell. Now with VEMS, and cage... Uzelac 62 110,759 06-22-2015 02:56 PM
Last Post: Uzelac
