Fiting toyota supercharger in 4 A-GE
04-27-2008, 12:41 AM
Hi, does anyone know if the blue top 16v 4 A-GE engine can be fited with the toyota MR-2 (AW-11) superchager?
[Image: AEU86 AE86 - Fiting toyota supercharger in 4 A-GE]
Regards
04-27-2008, 02:08 AM
if you have all the pipes and you can manage the ecu sure you can.
You need to change the injectors the intake side of the engine will be replaced by the SC. and so on. But remember the gze has a low compression piston. I think with teh US pistons of 9.4 you should manage but if you have 10 or higher I don't know what it will do. (maybe use a thicker headgasket.
  supercharger restrictor ditn 21 27,542 02-15-2013 10:03 PM
Last Post: ditn
  Help needed with 4AGZE supercharger heshan 5 8,097 10-31-2012 08:44 AM
Last Post: Rick
  Is there anyway to LOCK the supercharger pulley on 4agZe ? Okami 6 8,421 07-06-2012 12:58 PM
Last Post: Okami
  4agze --> SuperCharger will not power up/ Boost Gtsi-R 18 34,678 09-25-2011 09:38 PM
Last Post: Okami
  Can you add a blowoff to a supercharger? heshan 9 11,857 08-09-2010 01:00 AM
Last Post: heshan
