oldskull's Levin
04-16-2008, 09:54 PM
Post: #241
oldskull's Levin
So the struts and spindle is one piece? and if you want to fit coilovers or other dampers you need to hack and weld?
04-16-2008, 09:55 PM
Post: #242
oldskull's Levin
jep, this is how the struts originally look:
![]() that sucks donkey balls "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
04-16-2008, 10:00 PM
Post: #243
oldskull's Levin
I should think the struts are pressed into the spindle, just doesnt make sense to make a complex piece like that from one piece. I would not be very comfortable with just a weld keeping the whole strut connected to the spindle. Heat from welding can have the weirdest effects on material properties.
04-16-2008, 10:08 PM
Post: #244
oldskull's Levin
Same here, but then again, so much ae86 lowered, using coilovers, they al cut and welded the damper and spindle together?
04-17-2008, 08:27 PM
Post: #245
oldskull's Levin
99% of the time, coilover perches are either welded to the strut directly, or sat on a new perch that is welded to the strut. The difference to me is the fact that if a perch breaks off, you'll bottom out your suspension, but it will stay together as long as the shock doesnt break. If the whole strut breaks off of the spindle, then your front suspension falls apart.
04-17-2008, 09:10 PM
Post: #246
oldskull's Levin
Kan dat er eens in het nederlands onderaan?
04-18-2008, 06:10 PM
Post: #247
oldskull's Levin
V'ruit... Staat dat als die las breekt, en je veerpoot los komt van de naaf, je stukken verder van huis bent dan als alleen een veerschotel/coilover breekt..
08-10-2008, 07:29 PM
Post: #248
oldskull's Levin
Some update
08-10-2008, 07:56 PM
Post: #249
oldskull's Levin
jeps on your car way better!!
08-10-2008, 08:01 PM
Post: #250
oldskull's Levin
but still its look sooooo big like I got 16" rims now 1985 AE86 (ハチロク) Levin - Summer time daily driver |
![AEU86 AE86 - oldskull's Levin [Image: AEU86 AE86 - oldskull's Levin]](http://www.uwhost4.net/~hachi/voorpoten.jpg)
