Best modification
03-04-2008, 06:27 PM
Best modification
I've just completed the best modification so far to my '86
Quaife close ratio Ford type 9 gearbox with a TRD clutch, it's fantastic ![]() The car seems to come alive with a close ratio gearbox. It really suits the power output of even a standard 4AGE Strangely it's not a very common mod though.... An analogue brain in a digital World |
03-04-2008, 07:31 PM
Best modification
how about costs ?
AE86 FANATIC!!! |
03-04-2008, 08:13 PM
Best modification
alimonos Wrote:how about costs ?Scary yes, but probably less than a 20v conversion. I think it gives a comparable increase in performance. The noise is unbelievable, she wails like a banshee now OK though, 'cause it's a rally car ! An analogue brain in a digital World |
03-04-2008, 08:19 PM
Best modification
I´ve heard that.
Its a shame that a close gear ratio set is so damn expensive. ![]() Cump´s Filipe Oliveira |
03-04-2008, 08:54 PM
Best modification
Lipinhu Wrote:I´ve heard that.Yes the T50 Toyota gearset is very expensive and rare but a used Ford Type 9 is not too bad price wise and fairly common. I think a complete conversion could be done for around 1200 euros. Here are a few money saving tips: Find a used Type 9 CR (Quaife or Tranex) on that auction site. (600) Use a standard AE86 clutch cover and a MGB clutch plate. (50) Modify standard gearbox mount, easily done (20) Modify standard release (throwout) bearing, just bore it out to fit Type 9 shaft (20) Modify front half of propshaft to fit Ford output shaft (100) Get Raw engineering bellhousing and spigot bearing (300) Put it all together Numbers in brackets are approximate prices in Euros, my computer does'nt have a Euro key !!! An analogue brain in a digital World |
03-26-2008, 11:02 AM
Best modification
totta Crolla Wrote:I've just completed the best modification so far to my '86 It is also my best modification as well. I have TRD close ratio gearset in my T50 gearbox. It works really well with my 4agze. I love the long first gear it let me take advantage of the torque from the supercharger. I can almost do 80km/h in first! snap into second and there is hardly any drop in rpm and you just continue to accelerate oh yeah and the noise is cool too :mrgreen: |
05-15-2008, 04:48 AM
Best modification
Why not just go for a pinion and drive set?
05-22-2008, 08:53 PM
Best modification
Hmmmm.... I can't wait till the LOOOONG AZ6 project is done(going on 22 months now)....
![]() totta Crolla Wrote:The car seems to come alive with a close ratio gearbox. It really suits the power output of even a standard 4AGE I expect similar results!!!! Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-22-2008, 10:08 PM
Best modification
Wow...must be really expensive to get that bellhousing/front gearbox houding milled out of such a huge chuck of aluminum
05-23-2008, 02:00 AM
Best modification
The hunk of aluminum is $170.00 the CC time was about $1000 (first run no program). There are some necessary minor machine work the box still needs... but the case for all essential purposes is done......
I expect more soon..... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
| which is the best quality flywheel brand for 4age smallport? | LyndonAE86 NZ | 8 | 16,592 |
12-06-2012 01:20 AM Last Post: Bean |
| Best thing I have done to my car yet! | phill 92 | 7 | 10,387 |
07-16-2012 02:19 PM Last Post: gt4st205 |
| Best country to import "rust free" ae86? | EJ20 | 6 | 10,018 |
03-27-2012 06:57 PM Last Post: zenki |
| Best paint color for the 86? | heshan | 12 | 17,474 |
06-15-2010 10:51 PM Last Post: sergiocharged |
| Best choice for stability... | Serencebey | 8 | 9,544 |
03-17-2007 10:53 PM Last Post: NoHachi |
![AEU86 AE86 - Best modification [Image: AEU86 AE86 - Best modification]](http://lipinhu.no.sapo.pt/sbanner.jpg)
![AEU86 AE86 - Best modification [Image: AEU86 AE86 - Best modification]](http://i79.photobucket.com/albums/j143/oldeskewltoy/collageofadapter.jpg)
