Best modification
03-04-2008, 06:27 PM
Best modification
I've just completed the best modification so far to my '86
Quaife close ratio Ford type 9 gearbox with a TRD clutch, it's fantastic Smile
The car seems to come alive with a close ratio gearbox. It really suits the power output of even a standard 4AGE
Strangely it's not a very common mod though....
03-04-2008, 07:31 PM
Best modification
how about costs ? Dumb question
03-04-2008, 08:13 PM
Best modification
alimonos Wrote:how about costs ? Dumb question
Scary yes, but probably less than a 20v conversion. I think it gives a comparable increase in performance.
The noise is unbelievable, she wails like a banshee now Huh
OK though, 'cause it's a rally car !
03-04-2008, 08:19 PM
Best modification
I´ve heard that.
Its a shame that a close gear ratio set is so damn expensive.
[Image: AEU86 AE86 - Best modification]
Cump´s
Filipe Oliveira
03-04-2008, 08:54 PM
Best modification
Lipinhu Wrote:I´ve heard that.
Yes the T50 Toyota gearset is very expensive and rare but a used Ford Type 9 is not too bad price wise and fairly common. I think a complete conversion could be done for around 1200 euros.
Here are a few money saving tips:
Find a used Type 9 CR (Quaife or Tranex) on that auction site. (600)
Use a standard AE86 clutch cover and a MGB clutch plate. (50)
Modify standard gearbox mount, easily done (20)
Modify standard release (throwout) bearing, just bore it out to fit Type 9 shaft (20)
Modify front half of propshaft to fit Ford output shaft (100)
Get Raw engineering bellhousing and spigot bearing (300)
Put it all together Smile
Numbers in brackets are approximate prices in Euros, my computer does'nt have a Euro key !!!
03-26-2008, 11:02 AM
Best modification
totta Crolla Wrote:I've just completed the best modification so far to my '86
It is also my best modification as well. I have TRD close ratio gearset in my T50 gearbox. It works really well with my 4agze. I love the long first gear it let me take advantage of the torque from the supercharger. I can almost do 80km/h in first! snap into second and there is hardly any drop in rpm and you just continue to accelerate oh yeah and the noise is cool too :mrgreen:
05-15-2008, 04:48 AM
Best modification
Why not just go for a pinion and drive set?
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
05-22-2008, 08:53 PM
Best modification
Hmmmm.... I can't wait till the LOOOONG AZ6 project is done(going on 22 months now)....
totta Crolla Wrote:The car seems to come alive with a close ratio gearbox. It really suits the power output of even a standard 4AGE
I expect similar results!!!!
Dan -
05-22-2008, 10:08 PM
Best modification
Wow...must be really expensive to get that bellhousing/front gearbox houding milled out of such a huge chuck of aluminum Huh
05-23-2008, 02:00 AM
Best modification
The hunk of aluminum is $170.00 the CC time was about $1000 (first run no program). There are some necessary minor machine work the box still needs... but the case for all essential purposes is done......
I expect more soon.....
Dan -
  which is the best quality flywheel brand for 4age smallport? LyndonAE86 NZ 8 16,596 12-06-2012 01:20 AM
  Best thing I have done to my car yet! phill 92 7 10,388 07-16-2012 02:19 PM
Last Post: gt4st205
  Best country to import "rust free" ae86? EJ20 6 10,020 03-27-2012 06:57 PM
Last Post: zenki
  Best paint color for the 86? heshan 12 17,475 06-15-2010 10:51 PM
Last Post: sergiocharged
  Best choice for stability... Serencebey 8 9,548 03-17-2007 10:53 PM
Last Post: NoHachi
