GT4 Jap demo with Falken Skyline an Nordschleife
12-14-2004, 06:34 AM
senna Wrote:And now there is a time-limit removal for this version of GT4.Gimme gimme gimme! Damn i'm glad i was wrong about this! Edit: Found it here: http://www.gtplanet.net/forum/showthread...e=48&pp=20 and the trick is: ---- method: 1. use ISOBuster to extract all files from the iso (ho-gt4d.iso) or from burned DVDR 2. download AXE from here http://www.jbrowse.com/products/axe/download.shtml 3. install it and run it 4. open PCPX_966.49 file with AXE 5. look at offset column and scoll down to 001F0740 6. you will see that row like this FF FF 42 24 07 00 40 14 .... and you change the first 8 digits to FF 00 FF 00 .... then that line should be FF 00 FF 00 07 00 ... 7. Save and overwrite PCPX_966.49 8. repack all files and burn to Repack (for swap magic user, picky ps2, and for those who don't how to make a proper iso) I use Sony cd/dvd-rom generator (search yahoo with "$ony cd/dvd-rom generator") New Project > DVD Master Disc volume set to GRANTURISMO4, Disc Name PCPX - 96649, others blank in Directory, drag files into the program in following order: SYSTEM.CNF PCPX_966.49 IOPRP300.IMG IRX (folder) EPSON (folder) GT4.VOL after you press "rec" button, it will pop up a box for export temporary iml file, use GT4DEMO or whatever (not important) then it pop up 2 error box, first one is "recording unit is not connected", 2nd one is "initialization failed" ... ignore them then you should see a program called "CD/DVD-ROM Recording unit controller v1.xx" click file, export image, type GT4DEMO (LST file type) after it finish the process, you should have GT4DEMO.000 GT4 DEMO.001 then use command prompt (Start menu > Run > type cmd) and go to the folder where GT4DEMO.000 located type this: copy /b GT4DEMO.000 + GT4DEMO.001 GT4DEMO.iso wait a while, you will obtain GT4DEMO.iso in the same folder use Nero or DVD Decrypter to burn the iso image then now ... you can enjoy Nurburgring without time limit ... YAY! ---
12-14-2004, 07:47 AM
i just couldn't agree more
just was unsure how much "the powers that be" would like it He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
12-14-2004, 08:19 AM
senna Wrote:i just couldn't agree moreIt's just a hexedit of a free demo, i don't see how The Powers would dislike it. ![]() Writing this is less illegal than if i wrote a how-to about overspeeding at the highway!
12-14-2004, 12:58 PM
Haha, your right, let me cover that part.
How to overspeed on a highway by Senna for dummies: 1. make sure your on a highway 2. shift up till your in fifth gear 3. step on the most right pedal 4. keep doing that untill the speedo points 290 degrees downwards 5. tap yourself on the back, you did it! note: while doing this, try to avoid hitting too much moving objects. The damage to your own car can be severe, and will probably not be covered by your insurance company. He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
12-14-2004, 04:41 PM
LOL :lol:
12-14-2004, 05:17 PM
Will try this at home tonight
Thanks for sharing Michel Daily driver: Seat Leon Cupra V6 Summercar: E30 M3 Cecotto Projectcar: AE86 |
12-15-2004, 02:06 AM
senna Wrote:Haha, your right, let me cover that part. ah, now i understand. Everytime i'm going off to overspeed on the highway, i put it in 'R' from racemode. My car gains so much power that i broke 3 gearboxes and 2 engines "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
12-15-2004, 10:20 AM
The Doctor Wrote:Everytime i'm going off to overspeed on the highway, i put it in 'R' from racemode. Isn't "R" supose to mean "Rally" mode? :o Drifting - best fun you can have in your car with your pants on! |
| Jap Import Games | TakeItSideways | 7 | 14,745 |
03-13-2014 05:14 PM Last Post: MC_JP |
| GT4 challenge? | NoHachi | 62 | 78,509 |
01-24-2007 04:40 PM Last Post: TKD-Wolf |
| couple of drift videos GT4 | Apolan | 15 | 23,197 |
05-08-2005 02:29 AM Last Post: Apolan |
| gt4 drift settings???? | zeetee | 2 | 9,382 |
04-17-2005 04:00 PM Last Post: robokill |
| GT4 is out! | ZaX | 29 | 40,753 |
04-12-2005 02:56 PM Last Post: Mux213 |
