Clutch types for AE86
03-15-2007, 11:28 PM
there are of the shelf clutches that fit for the box and are 212mm dia. and i already have the ze flywheel on. is there any way of modifying the 1ggte bellhousing to fit a 4age engine, even if a little alu welding is needed?
Its gotta go whoosh or give a whine!!!! |
03-16-2007, 11:07 AM
Maybe adapter plate between the bellhousing and T50 ?
Measure length of T50's (primary) shaft also with bellhousing "attached" to T50. |
03-16-2007, 01:49 PM
"there are of the shelf clutches that fit for the box and are 212mm dia."
What clutch is that??? /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
03-18-2007, 07:03 PM
im not sure. when my brother did the swap, he went up to this place in Belfast that only do clutches and they had one 212mm on the correct splines. i may be confused though and they had 212 plates and changed the spline. ill ask him and find out, it would be so much easier if i was back home.
03-18-2007, 07:07 PM
Today's update:
Some Peugeot clutches use the same splines and are 230mm diameter. If someone uses custom fluwheel - they can fit (in fact I measured 212mm flywheel and there is enough place for 230mm work area). The clutch used in this experiment was Peugeot 605 2.0 8V turbo one, the Peugeot owner said that Peugeot 405 T16 use the same. |
04-24-2007, 08:52 PM
Got my clutch when i was home, he had to split 3 different kits to make one clutch, cost £60 which i cant really argue with cos the guy is always interested in the car rather enjoys making clutches rather than off the shelf. that included the pressure plate and release bearing.
clark bros in belfast. Its gotta go whoosh or give a whine!!!! |
07-09-2007, 03:37 PM
Does anybody know which brand is the AE92GTi factory clutch plate? This is the 212mm diameter, P/N 31250-17020 or 31250-12320 - no difference imho.
I thought it should be Aisin as many other parts and like the AE86 factory clutch but according to a dealer it isn't. I was told it is something like NKK or whatever... Can somebody help me out with this please? 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
11-18-2007, 09:52 PM
Could someone please advise if the aw11 clutch has the same splines as the ae86?
There is one on ebay that I might buy if I can use it. Regards Ian |
11-19-2007, 12:21 PM
If it is for 4AGE engine - yes, same splines.
Avoid 4AGZE ones. |
11-19-2007, 06:46 PM
Thanks for the reply Jamie..maybe I will bid on it now.
| rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 6,230 |
| Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 20,993 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
| Ae86 bulk head mod to fit hydrolic clutch? | dinkers542 | 8 | 13,247 |
11-25-2014 09:21 PM Last Post: dinkers542 |
| AE86 halfshaft types? | TheGerman | 6 | 15,021 |
11-27-2012 08:02 PM Last Post: fax0815 |
| Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, | dsrturbo | 2 | 7,705 |
07-28-2011 10:51 AM Last Post: Bean |
