| Author |
Message |
ZaX Moderator
Joined: 20 Sep 2004 Posts: 1440 Location: Croatia / Zagreb
Posted: Wed Feb 28, 2007 3:03 pm Post subject: JTuned AE86 |
AE86
Engine
TRD Formula Atlantic Spec 4AGE 20V Engine
1.6L with 12.8 to 1 Compression Ratio
TODA Racing camshaft IN 288/ EX 288 9.0 lift
TODA Valve springs
TODA cam gears
Special SS valves & valve guide
TRD 0.8mm head gasket
Escort Racing 81.25mm pistons
TRD connecting rods
TRD Crank Shaft
Special Modified oil pump
Haltech ECU
Setrab 19rows oil cooler
Griffin radiator
TRD close ratio/original transmission
Tilton Twin Plate clutch
Carbon driveshaft
KAAZ 2way LSD
4.8 final gear
Suspension
SWIFT front coilover springs/ rear coil springs
Front special fully adjustable shock housing with Tokiko HTS shocks
TRD sway bars
Battle Version(Alex Pfeiffer) special rod links and steering angle modification
Brakes
Hawk HT-10 brake pads
Earl's brake lines
Wheels
JDM Dori Dori mesh f:15x7/ r:15x7.5
Toyo Proxes T1-R 195/50/15
Exterior
FRP body kit
FRP rear hatch
Carbon Fiber hood
JDM taillights
Interior
Custom 6 point roll cage with full chassis stitch welding
Bride Zeta III bucket seats
Nardi Steering wheel
Pa jos....
Engine
AE92 Small Port High Compression 4AGE
HKS Valve Springs
HKS 272in / 264in 8.1 lift
HKS adjustable cam sprocket
HKS .7MM metal headgasket
HKS Sport exhaust
Mild street port head
KBD 4-2-1 Header
ARC Induction box
ARC Induction Pipe
Ae86 Map Sensor setup
A?pexi Engineering POWER FC computer
Ae111 Blitz radiator hose
HKS Iridium plugs
Setrab 24 row oil cooler
Greddy oil filter relocation kit
Cusco oil catch can
Koyo aluminum radiator
TRD 4.7 final gear
Kaaz 2way differential
Toda chromoly flywheel
ACT stage 2 w/ extreme pressure plate
T3 Short throw shifter
Suspension
Safety21 5pt roll bar
Jubiride mid chassis bar
Battleversion 4 link bars
Battleversion Traction bracket
Battleversion NRCA
Battleversion lateral bar
T3 front coilover setup 8kg
T3 rear coilover setup 6kg
KYB AGX sw20 front shock
KYB AGX camaro rear shock
Project MU camber plate
Cusco front strut bar
Cusco rear tri brace strut bar
TRD front sway bar
Brakes
Rotora Slotted rotors
Project MU B-Force Pads
Rotora Stainless steel brake lines
Wheels
Volk TE37 14x7 +0 offset (track)
Falken Azenis 615 (track)
Work Equip 03: 15x8 +0 offset (front), 15x8.5 -6 offset (rear)
Falken Ziex: 195/50/15 (front), 205/50/15 (rear)
Exterior
OEM Toyota kouki front bumper
OEM Toyota kouki rear bumper
OEM Toyota zenki front lip
OEM Toyota sideskirts
OEM Toyota Kouki Redline Taillights
Carbon bonnet
Interior
Bride Bracket
Recaro SPG
NRG quick release hub
Crow 4pt harness
Redone door panels
Clarion headunit
Blitz BLM oil pressure meter
Blitz BLM oil temp meter
Blitz BLM water temp meter
Engine
JDM High compress 9.5:1 4agze motor
JDM DLI Map wire harness rewired
AE101 GZE DLI ECU
HKS Cam gears (old school black gears, not the gay purple ones)
Nams pulley kit (for non-power stearing)
GT28RS dual BB Turbo
B-Tune 19 row oil cooler
Custom V-mounted intercooler
Custom V-mounted Koyo radiator
SS Custom Exhaust Manifold
Flex-A-Lite dual fan
Cusco catch can
2.5" downpipe
Samco radiator hoses (custom modded)
Beatrush levin radiator plate
Light weight battery
Samco silicone vacuum hoses
Red Hyper ground wires
HKS Windmaster exhaust
HKS Oil Cap
Blitz Radiator Cap
TRD Zenki LSD
Jun Ultra lightweight flywheel
Illegal Garage clutch set
T3 short shifter
Suspension
B-Tune/Swift Coilover suspension (7kg front, 4.7kg rear)
B-Tune Lower front control arms
Tokico HTS shocks
Nams Gacchiri Support (Fender brace)
Nams Shakkito Strut Top plate
Ueo style inner and outer tie rods
Battle Version rear lateral bar
Battle Version Tension rods
TRD Bushing set
Techno Pro Spirit rear strut bar
Jubiride Traction brackets
Tein camber plates
Brakes
Endless 4 pot front caliper upgrade
Endless SS brake lines
slotted and rear rotors
Wheels
Work Miester 15x9.5 -31 offset wheels in gold (front)
Work Miester 15x10 -38 offset wheels in gold (rear)
205/50/15 Falken ZE512 tires (street use for now) front
225/50/15 Falken ZE512 tires (street use for now) rear
Exterior
Levin kouki front end conversion
HID headlights
Yellow HID Fog lights
CBY Levin Front bumper
CBY Flares
CBY Side Skirts
CBY Mirrors
B-Tune Carbon Fiber Vented Levin hood
Jubiride rear diffusors
TRD rear Spoiler
Shaved side markers
Retractable antenna
JDM Levin Door visors
JDM rear kouki bumper
Ueo Style Tow hook kit
Two tone red and black paint job (by B-Tune)
Fenders cut and welded (by B-Tune)
Interior
Nardi Redline Steering wheel
Nardi telescopic hub
KeiChi Shift knob
Eclipse 7301 double din HU
Pioneer front Speakers
SoundStream 2 channel rear speakers
2 bride Brix 1 seats (red)
Tom's pedals
HKS Turbo Time (old school one)
Defi BF Boost guage
Defi BF Fuel Pressure guage
Engine
1991 JDM 4AGE 16valve (redtop)
C's short shifter
HKS super mega flow filter
HKS hi-power exhaust system
HKS adjustable cam gears
HKS D1 limited edition radiator cap
HKS D1 limited edition oil cap
HKS circle earth grounding system
HKS lightened flywheel
Danstoy Custom race clutch
Danstoy Custom intake manifold
Direct Power system version 1
NGK iridium IX spark plugs
NGK high-tension wires
Suspension
TRD lowering springs
Tokico gas shocks
Tanabe front sway bar
Tanabe rear sway bar
Tanabe front tower bar
Brakes
Rotora slotted rotor (F)
Rotora slotted rotor ®
Rotora brake pads
Rotora braided lines
Wheels
15x8.5 (F) & 15x9.5 ® Work Wheels Equip 03
195/50/15 (F) & 205/50/15 ® Yokohama ES-100
Exterior
Run Free front bumper
Run Free sideskirts
Run Free rear bumper
Run Free front replacement wide fenders
Run Free rear wide over fenders
Run Free fiberglass hatch
Run Free carbon hood
Kouki front bumper lights
Kouki redline tail lights
Kouki front grille
Subaru Gold
Interior
Bride Zeta III Racing Seats
Bride Fabric Carpets
Bride Fabric Door Panels
Bride windshield visors
Bride Fabric Re-upholstered Rear Seats
Nardi Steering Wheel
Team Tech 4-point harness
Splash steering hub
Rapfix quick release system with lock
HKS D1 Limited Edition Shift Knob
Kenwood single CD player
_________________ Go-Drift.com
| Back to top |
mc68 Wataru
Joined: 16 Jan 2007 Posts: 64 Location: Perth, Western Australia
Posted: Wed Feb 28, 2007 3:29 pm Post subject: |
Annnnd i just ruined another pair of pants.
seriously, oh my lord, those cars are just the pinncale of of... no word descirbes it!
| Back to top |
alimonos Bunta
Joined: 10 Jan 2005 Posts: 2603 Location: HPEIROS - GREECE
Posted: Wed Feb 28, 2007 3:30 pm Post subject: |
_________________ AE86 FANATIC!!!
| Back to top |
Apolan Bunta
Joined: 27 Nov 2004 Posts: 1851 Location: Slovenia, Ljubljana
Posted: Wed Feb 28, 2007 3:51 pm Post subject: |
that last runfree one is pretty basic actually. i love that gray trueno coupe. come to thik about it, i had a dream about a car just like this one a couple of weeks ago - grey trueno coupe with gold stickers... wierd.
btw: where can i get a complete ground-leads kit for the engine bay, like in that last runfree car? (just in some more basic colours, like black..)
_________________ There are no good decisions or bad decisions - only deciding or running away.
-me, 2007
| Back to top |
andrecorreia Iketani
| Back to top |
Apolan Bunta
| Back to top |
dollykean Ryousuke
1982 Toyota Other corolla
Posted: Wed Feb 28, 2007 10:09 pm Post subject: |
WAOUH!!!!
Thanks for those pics, the header of the first one is awesome!!!
And of Course THANKS!!!
_________________
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Wed Feb 28, 2007 10:44 pm Post subject: |
Nice!
Recognize the fourth (panda red) from something else... Can't remember what.
| Back to top |
cannabolic Takumi
Posted: Wed Feb 28, 2007 10:53 pm Post subject: |
thx ZaX!!!!!!!!!
_________________ Philip
'86 Red hachi
'03 Silver BigHit
| Back to top |
DJexor Moderator
Joined: 24 Oct 2004 Posts: 1493 Location: Netherlands, Den Haag
Posted: Wed Feb 28, 2007 11:11 pm Post subject: |
i want some on A0 paper!!! my room have to be filled with these cars!!
_________________
9/2001 Toyota Yaris 1.5 T-Sport
| Back to top |
CircuitFreak Takumi
Posted: Thu Mar 01, 2007 11:06 pm Post subject: |
Really nice pics an good info.
Do you also got more pics and info about this cars?
_________________
Toyota MR2 2.0 16V Twincam GTI.
Toyota Corolla GTZ Twincam 1.6 16V (AE86)
| Back to top |
oli Wataru
Posted: Fri Mar 02, 2007 10:04 am Post subject: |
WOW!
loving the stryling of the black 2 door trueno.
but the gold one is hotness and fave colour.
fave rims are the dori ones in the first one
nice find and post Mr ZaX!
_________________
| Back to top |
frass_2k4 Iketani
Posted: Wed Jul 16, 2008 4:51 pm Post subject: |
wonder if my car can ever look like those. sniff sniff
_________________ make more money than you thought possible
http://p4pp7hfj79xgsa2bqtk.usercash.com
| Back to top |
quickster
Posted: Sun Aug 31, 2008 4:43 am Post subject: |
| CircuitFreak wrote: |  |
that one is my cousins car
heres a much more recent pic
_________________ www.flickr.com/quickster
| Back to top |
eightsix
Posted: Sat Oct 18, 2008 6:24 am Post subject: |
heythere, i was hoping to get the color number of tpiant used on the car. | quickster wrote: | | CircuitFreak wrote: |  |
| Back to top |
gtapex
Posted: Wed Dec 10, 2008 8:52 pm Post subject: |
nice
where would you get Carbon driveshaft?
| Back to top |
