JTuned AE86
02-28-2007, 03:03 PM
JTuned AE86
AE86
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Engine TRD Formula Atlantic Spec 4AGE 20V Engine 1.6L with 12.8 to 1 Compression Ratio TODA Racing camshaft IN 288/ EX 288 9.0 lift TODA Valve springs TODA cam gears Special SS valves & valve guide TRD 0.8mm head gasket Escort Racing 81.25mm pistons TRD connecting rods TRD Crank Shaft Special Modified oil pump Haltech ECU Setrab 19rows oil cooler Griffin radiator TRD close ratio/original transmission Tilton Twin Plate clutch Carbon driveshaft KAAZ 2way LSD 4.8 final gear Suspension SWIFT front coilover springs/ rear coil springs Front special fully adjustable shock housing with Tokiko HTS shocks TRD sway bars Battle Version(Alex Pfeiffer) special rod links and steering angle modification Brakes Hawk HT-10 brake pads Earl's brake lines Wheels JDM Dori Dori mesh f:15x7/ r:15x7.5 Toyo Proxes T1-R 195/50/15 Exterior FRP body kit FRP rear hatch Carbon Fiber hood JDM taillights Interior Custom 6 point roll cage with full chassis stitch welding Bride Zeta III bucket seats Nardi Steering wheel Pa jos.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Engine AE92 Small Port High Compression 4AGE HKS Valve Springs HKS 272in / 264in 8.1 lift HKS adjustable cam sprocket HKS .7MM metal headgasket HKS Sport exhaust Mild street port head KBD 4-2-1 Header ARC Induction box ARC Induction Pipe Ae86 Map Sensor setup A?pexi Engineering POWER FC computer Ae111 Blitz radiator hose HKS Iridium plugs Setrab 24 row oil cooler Greddy oil filter relocation kit Cusco oil catch can Koyo aluminum radiator TRD 4.7 final gear Kaaz 2way differential Toda chromoly flywheel ACT stage 2 w/ extreme pressure plate T3 Short throw shifter Suspension Safety21 5pt roll bar Jubiride mid chassis bar Battleversion 4 link bars Battleversion Traction bracket Battleversion NRCA Battleversion lateral bar T3 front coilover setup 8kg T3 rear coilover setup 6kg KYB AGX sw20 front shock KYB AGX camaro rear shock Project MU camber plate Cusco front strut bar Cusco rear tri brace strut bar TRD front sway bar Brakes Rotora Slotted rotors Project MU B-Force Pads Rotora Stainless steel brake lines Wheels Volk TE37 14x7 +0 offset (track) Falken Azenis 615 (track) Work Equip 03: 15x8 +0 offset (front), 15x8.5 -6 offset (rear) Falken Ziex: 195/50/15 (front), 205/50/15 (rear) Exterior OEM Toyota kouki front bumper OEM Toyota kouki rear bumper OEM Toyota zenki front lip OEM Toyota sideskirts OEM Toyota Kouki Redline Taillights Carbon bonnet Interior Bride Bracket Recaro SPG Nardi Steering wheel NRG quick release hub Crow 4pt harness Redone door panels Clarion headunit Blitz BLM oil pressure meter Blitz BLM oil temp meter Blitz BLM water temp meter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Engine JDM High compress 9.5:1 4agze motor JDM DLI Map wire harness rewired AE101 GZE DLI ECU HKS Cam gears (old school black gears, not the gay purple ones) Nams pulley kit (for non-power stearing) GT28RS dual BB Turbo B-Tune 19 row oil cooler Custom V-mounted intercooler Custom V-mounted Koyo radiator SS Custom Exhaust Manifold Flex-A-Lite dual fan Cusco catch can 2.5" downpipe Samco radiator hoses (custom modded) Beatrush levin radiator plate Light weight battery Samco silicone vacuum hoses Red Hyper ground wires HKS Windmaster exhaust HKS Oil Cap Blitz Radiator Cap TRD Zenki LSD Jun Ultra lightweight flywheel Illegal Garage clutch set T3 short shifter Suspension B-Tune/Swift Coilover suspension (7kg front, 4.7kg rear) B-Tune Lower front control arms Tokico HTS shocks Nams Gacchiri Support (Fender brace) Nams Shakkito Strut Top plate Ueo style inner and outer tie rods Battle Version rear lateral bar Battle Version Tension rods TRD Bushing set Techno Pro Spirit rear strut bar Jubiride Traction brackets Tein camber plates Brakes Endless 4 pot front caliper upgrade Endless SS brake lines slotted and rear rotors Wheels Work Miester 15x9.5 -31 offset wheels in gold (front) Work Miester 15x10 -38 offset wheels in gold (rear) 205/50/15 Falken ZE512 tires (street use for now) front 225/50/15 Falken ZE512 tires (street use for now) rear Exterior Levin kouki front end conversion HID headlights Yellow HID Fog lights CBY Levin Front bumper CBY Flares CBY Side Skirts CBY Mirrors B-Tune Carbon Fiber Vented Levin hood Jubiride rear diffusors TRD rear Spoiler Shaved side markers Retractable antenna JDM Levin Door visors JDM rear kouki bumper Ueo Style Tow hook kit Two tone red and black paint job (by B-Tune) Fenders cut and welded (by B-Tune) Interior Nardi Redline Steering wheel Nardi telescopic hub KeiChi Shift knob Eclipse 7301 double din HU Pioneer front Speakers SoundStream 2 channel rear speakers 2 bride Brix 1 seats (red) Tom's pedals HKS Turbo Time (old school one) Defi BF Boost guage Defi BF Fuel Pressure guage ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Engine 1991 JDM 4AGE 16valve (redtop) C's short shifter HKS super mega flow filter HKS hi-power exhaust system HKS adjustable cam gears HKS D1 limited edition radiator cap HKS D1 limited edition oil cap HKS circle earth grounding system HKS lightened flywheel Danstoy Custom race clutch Danstoy Custom intake manifold Direct Power system version 1 NGK iridium IX spark plugs NGK high-tension wires Suspension TRD lowering springs Tokico gas shocks Tanabe front sway bar Tanabe rear sway bar Tanabe front tower bar Brakes Rotora slotted rotor (F) Rotora slotted rotor Rotora brake pads Rotora braided lines Wheels 15x8.5 (F) & 15x9.5 Work Wheels Equip 03 195/50/15 (F) & 205/50/15 Yokohama ES-100 Exterior Run Free front bumper Run Free sideskirts Run Free rear bumper Run Free front replacement wide fenders Run Free rear wide over fenders Run Free fiberglass hatch Run Free carbon hood Kouki front bumper lights Kouki redline tail lights Kouki front grille Subaru Gold Interior Bride Zeta III Racing Seats Bride Fabric Carpets Bride Fabric Door Panels Bride windshield visors Bride Fabric Re-upholstered Rear Seats Nardi Steering Wheel Team Tech 4-point harness Splash steering hub Rapfix quick release system with lock HKS D1 Limited Edition Shift Knob Kenwood single CD player Drifting - best fun you can have in your car with your pants on! |
02-28-2007, 03:29 PM
JTuned AE86
Annnnd i just ruined another pair of pants.
seriously, oh my lord, those cars are just the pinncale of of... no word descirbes it! |
02-28-2007, 03:30 PM
JTuned AE86
AE86 FANATIC!!! |
02-28-2007, 03:51 PM
JTuned AE86
that last runfree one is pretty basic actually. i love that gray trueno coupe. come to thik about it, i had a dream about a car just like this one a couple of weeks ago - grey trueno coupe with gold stickers... wierd.
btw: where can i get a complete ground-leads kit for the engine bay, like in that last runfree car? (just in some more basic colours, like black..) |
02-28-2007, 05:27 PM
JTuned AE86
these cars are beautifully
where i can buy pedals like the ones on the photo to my racing car??? Always on top always on sideways http://img512.imageshack.us/img512/6080/...tomrx5.jpg |
02-28-2007, 06:24 PM
| JTuned AE86 | |||
02-28-2007, 10:09 PM
JTuned AE86
WAOUH!!!!
Thanks for those pics, the header of the first one is awesome!!! And of Course THANKS!!!
1982 Toyota Corolla KE70 1992 Subaru Legacy BF5T |
02-28-2007, 10:44 PM
JTuned AE86
Nice!
Recognize the fourth (panda red) from something else... Can't remember what. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
02-28-2007, 10:53 PM
JTuned AE86
thx ZaX!!!!!!!!!
Philip |
02-28-2007, 11:11 PM
JTuned AE86
i want some on A0 paper!!! my room have to be filled with these cars!!
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/001.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/002.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/003.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/004.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/005.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/006.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/007.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/008.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/009.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/010.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/011.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/012.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/013.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/014.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/015.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/016.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/017.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/018.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/019.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/020.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Martin%20Harjani/021.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/001.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/003.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/004.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/005.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/006.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/007.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/008.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/009.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/010.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/011.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/012.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/013.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/014.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/015.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/016.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/017.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/018.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/019.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/020.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/021.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/022.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/023.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/025.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/026.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/027.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20AE86%20Hasselgren/028.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/001.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/002.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/003.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/004.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/005.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/006.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/007.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/008.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/009.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/010.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/011.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/012.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/013.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/014.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/015.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/016.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/017.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/018.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/019.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%20AE86%20Ron%20Ng/020.jpg.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/001.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/002.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/003.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/004.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/005.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/006.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/007.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/008.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/009.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/010.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/011.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/012.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/013.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/014.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/015.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/016.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/017.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/018.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/019.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/020.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/021.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/022.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/023.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Toyota%20Corolla%2086%20Ron%20Woo/025.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/01.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/02.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/03.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/05.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/06.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/07.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/08.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/09.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/10.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](http://www.jtuned.com/media/gallery/articles/Midnight%20Run2/Allen86/11.jpg)
![AEU86 AE86 - JTuned AE86 [Image: AEU86 AE86 - JTuned AE86]](https://www.aeu86.org/sticker-banner-468.gif)
