Shifting Weight
Goto page 1, 2  Next
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Drifters
Author Message
TakeItSideways
PostPosted: Fri May 05, 2006 5:47 am    Post subject: Shifting Weight Reply with quote
hey guys.
im kinda new to the drifting scene, and i am having some problems with my 86 drift.
i can countersteer out of a drift ok and all, but going into one im lacking somethin. im thinkin that i need to shift the car weight more to the other side for outer force, but i cant get it to happen.
can ne 1 tell me how to better shift the car's weight?
thx
Back to top
View user's profile Send private message AIM Address
Ivan141
Moderator
PostPosted: Fri May 05, 2006 7:27 am    Post subject: Reply with quote
I'm by no means a drifter, but if you want to initiate your drift using weight shifting you'll have to practice your feint drifting (otherwise known as the scandinavian flick). Before turning into the corner first steer sharply in the opposite direction and back again. You should look up some Formula Drift vids, one of the club4AG drifters clearly uses the technique all the time (taka or hiro...dont know which one).
_________________
'81 poor guy with a money-pit
Back to top
jnk
Iketani
1987 Toyota Corolla AE86 (late EU)
PostPosted: Fri May 05, 2006 9:19 am    Post subject: Reply with quote
i am total beginner and the most easy technique to initiate slide without handbrake is hard braking(weight transfer from rear to front) combined with shift lock a little after "weight is transfered".
Back to top
Ivan141
Moderator
PostPosted: Fri May 05, 2006 9:34 am    Post subject: Reply with quote
That'll work too, but is not too good for your tyres and driveline..
_________________
Back to top
jnk
Iketani
PostPosted: Fri May 05, 2006 9:38 am    Post subject: Reply with quote
any kind of drifting is killing tyres.
yeah, shift lock is bad for driveline, but not SO much, when weight is transferred. i dont recommend to use shift lock without braking, sometimes people love to do that.
Back to top
Ivan141
Moderator
PostPosted: Fri May 05, 2006 9:39 am    Post subject: Reply with quote
Locking the tyres will wear them down flat in spots...much more so than any other drift method (except for the handbrake), I'd rather have more even tyre wear.
_________________
Back to top
jnk
Iketani
PostPosted: Fri May 05, 2006 10:17 am    Post subject: Reply with quote
i havent seen the car from outside, when doing that Wink, but i dont think that tires r locked at that moment. they r just slipping, just like when braking on lock limit.
Back to top
Dorito86
Moderator
1978 Austin Mini
PostPosted: Fri May 05, 2006 11:31 am    Post subject: Reply with quote
You can tell when a driver has used the handbrake. It shows on the rear wheels and it shows on the abruptness of break of traction.
@TakeItSideways: Sounds like you're having the same problems I had in the beginning. I assume you also have stock suspension. The problem is that you brake too early into the corner. That combined with the fact of worn bushings and soft suspension means that you don't make full use of weight transfer and the suspension parts absorb most of what you DO transfer. My advice is: Get the drift bible and learn it by heart Smile Then you can try worn rear tyres. The rear will break loose much easier, even with very little weight transfer. Worn rear tyres will also help you when trying to brake late into the corner. Most stock AE86 will understeer during hard brake&turn situations and worn rear tyres help balance things out.
Apart from that, increase the responsiveness of your car to torsional changes. Only way to do that is get some fresh bushings and better springs-shocks. The more responsive the car, the better your chances of getting it right.
Good luck
Back to top
dAYTONA
Takumi
PostPosted: Fri May 05, 2006 1:15 pm    Post subject: Reply with quote
Ivan: I really don't understand how you can talk about even tyre wear....
who cares how they wear... it's drifting, tyres wear out within minutes... it's not the Le Mans, where flat spots will hurt your performace... and you won't get flat spots from a short lockup... not noticable anyway.
_________________
Koukis - Red, Silver/Gray,
Back to top
View user's profile Send private message Visit poster's website MSN Messenger Skype Name
Ivan141
Moderator
PostPosted: Fri May 05, 2006 1:45 pm    Post subject: Reply with quote
I'm only try a little drift occasionally, I dont switch tyres, and I dont shred them to pieces in 15 minutes. Therefore flatspots suck and will throw off the balance of the wheel too much. Furthermore your differential and gearbox are not built to suddenly lock up, and you will wear things down much faster, or break stuff. I think it's a sloppy way of handling your material, if you want to do this, try it in the rain.
_________________
Back to top
Apolan
Bunta
PostPosted: Fri May 05, 2006 1:48 pm    Post subject: Reply with quote
just speed into a corner, accel off and do the flick (left-right). that makes even the passenger bus go sideways Very Happy
_________________
There are no good decisions or bad decisions - only deciding or running away.
-me, 2007
Back to top
TakeItSideways
PostPosted: Fri May 05, 2006 4:46 pm    Post subject: Reply with quote
thx for the tips guys
but wont loosening the grip on the rear tires make too hard to exit the turn because of too much oversteer?
same with the flick tech. ive tried it and, probably im doing it too much or too long, but i cant exit the drift from the oversteer.
Back to top
el_chico
Wataru
PostPosted: Fri May 05, 2006 7:19 pm    Post subject: Reply with quote
Feint works very well with my hachi, but that haves to do because the suspension setup, last year with my past s14a, i could only drift with clutch kicks, shift locks and handbrake .. without weight shifting then. Hachi rules Thumbsup
_________________
Back to top
Dorito86
Moderator
1978 Austin Mini
That will only help you learn better throttle control. Only pros can get away with flooring it all the time. Learn to coordinate countersteer with gas. More gas, more oversteer, more counterster. Countersteer has to be done early. If you wait too long, you'll spin.
As for the corner exit rear end grip, for me the best learning day was at an empty lot with loads of rain falling. Minimum grip, low speeds, exagerated car response to all input i gave it. Give it a try (next yar probably Puh )
Back to top
TakeItSideways
PostPosted: Sat May 06, 2006 12:52 am    Post subject: Reply with quote
in regards to the feint drift how long and how much should i been steering.
is it like a half second flick or a 2 second flick? and do i just budge the wheel or make a 90 degree turn of the wheel?
Back to top
Dorito86
Moderator
1978 Austin Mini
PostPosted: Sat May 06, 2006 10:48 am    Post subject: Reply with quote
It really depends on how fast you're going and on the state of your suspension and tyres. There's no definite answer to this.
Back to top
Ivan141
Moderator
PostPosted: Sat May 06, 2006 10:50 am    Post subject: Reply with quote
like some of the others said, watch keichi's drift bible...ot top gear's burning rubber vid, where ex-F1 driver Tiff Needell gets a fwd ford sideways using the scandinavian flick... That should give you an idea.
But the best way IMHO, would be to get out there and practice in a safe place.
_________________
Back to top
hamsupjai
Iketani
PostPosted: Sat Jul 22, 2006 12:57 pm    Post subject: Reply with quote
cant believe that england has such sunny weather for once. in a way bad for drifters lol good for blackpool beach.
as for weight shifting. i must agree with dorito86, maybe your suspension is set on being too soft hence you cant fully transfer all of the cars weight when you want to flick it into the corner. the handbreak is alway useful if you were unsucessful with the feint drift
Back to top
NoHachi
Moderator
PostPosted: Sat Jul 22, 2006 1:17 pm    Post subject: Reply with quote
Soft and hard suspensions will both shift exactly the same amount of weight I'm affraid.
_________________
Scuderia Rollator
Back to top
hamsupjai
Iketani
PostPosted: Sat Jul 22, 2006 1:26 pm    Post subject: Reply with quote
NoHachi wrote:
Soft and hard suspensions will both shift exactly the same amount of wight I'm affraid.
that is true, the car weighs excatly the same whether you have soft or hard suspension but with stiffer suspension, you get to shift more aggressively the weight of the car thus creating a more weight transfer.
Back to top
Ivan141
Moderator
PostPosted: Sat Jul 22, 2006 6:37 pm    Post subject: Reply with quote
The stiffness of your suspension only dictates the speed in which weight is shifted. The stiffer it gets, the slower the weight transfer will be.
_________________
Back to top
NoHachi
Moderator
PostPosted: Sat Jul 22, 2006 9:20 pm    Post subject: Reply with quote
Ghe ghe...WRONG! Smile
Ok a car with a given wheelbase and weight in a certain G-corner, shifts exactly the same amount of mass..its simple physics..draw a free body diagram and all will be clear. So hamsup: the weight transfer is the same too.
Ivan, a stiffer suspension shift weight more quickly then a soft suspension. not the other way around. It makes it easier to induce a shockload on the tires and break them loose..It also means that the transition fase is over more quickly.
_________________
Scuderia Rollator
Back to top
hamsupjai
Iketani
PostPosted: Sat Jul 22, 2006 10:12 pm    Post subject: Reply with quote
ok ok just to let you know i m not trying to start an argument here just want to debate ok Very Happy
on my earlier post i said.
i think rewording what i should had said is
that is true, the car weighs excatly the same whether you have soft or hard suspension but with stiffer suspension, you get to shift more aggressively the weight of the car thus creating a more effective weight transfer.
Back to top
maggkrabar
Wataru
PostPosted: Sun Jul 23, 2006 12:43 am    Post subject: Reply with quote
I bet on this Smile we have dynamic system, corner ballansing, not static - so stiffer spring shifts more weight, stiffer shock "tells" to spring to shift the weight quicker. and all that weight is shifted not from one side of the car to other - all weight is at contact spots of tires(friction circles) and generates traction.
in an hour may be Smile but in miliseconds - not. stiffer=quicker
_________________
84' AE86 Levin
96' 500HP WRX, powered by landikar
Back to top
NoHachi
Moderator
PostPosted: Sun Jul 23, 2006 4:01 pm    Post subject: Reply with quote
Thats exactly what I wrote down..Exactly the same amount shifted, but quicker. In the end, the corner you take has a fixed radius..so the whole one hour story isn't true either:
same corner
same car
same line
same weight shifted
_________________
Scuderia Rollator
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Drifters All times are GMT + 2 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot attach files in this forum
