Kristians track setup
09-17-2005, 10:42 PM
Bastiaan...
Thanxs you for a great idea for a new forum this last Wednesday i was supposed to go trackdriving at Sturup Raceway. (se picture of track) But my broken diff -I´m having problems getting it apart - stopped me. On the first of Octobre i´m going to Ring Knutstorp (se picture of track) just 12 kms south of me, for a whole day´s trackdriving with the Swedish honda Club. My drift set-up is not that big in difference from the new track set-up. Here are the differences: Drifting set-up ! Front suspension: Coilovers to 0 percent (as soft as possible) KÓNI´s set to SOFT Rear suspension: KONI´s set to 85-95% stiffness Twin swaybars installed & adjusted front tires: TOYO T1-R 195/55-14, semi R-rated front rims: 6,5 x 14 rear tires: TOYO Cleanproxes, 174/65-14, studless snowtires rear rims: 6,5 x 14 ------------------------------------------------ Track set-up ! Front suspension: Coilovers set to 65% stiffness Rear suspension: KONI´s set to 55% stiffness twin swaybars still installed, but bolts loosened front tires: TOYO R888 185/55-15 R-raded with Supersoft compound front rims: 7 x 15 rear tires: TOYO R888 215/50-15 R-raded with Supersoft compound rear rims: 8,2 x 15 I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-18-2005, 12:11 AM
Damn, those new toyo tires should be something. The old tires they are replacing were renowned for their durability on track. Let me know how you like them.
09-18-2005, 12:14 AM
NoHachi Wrote:Damn, those new toyo tires should be something. The old tires they are replacing were renowned for their durability on track. Let me know how you like them. i belive this set-up will kick som serious Honda V-tec ass I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-18-2005, 02:25 AM
Quote:Front suspension: Coilovers to 0 percent (as soft as possible) Doesnt this make the front re-act alittle to slowly??? or is that how you want it in drifting. I would have throught you would want about 45% stiffness so that the front isnt always absorbing all the bumps and changes in the corners. Cause being stiffer would allow better steering response wouldnt it? I once read that you shouldnt believe everything you read. |
09-18-2005, 08:53 AM
Split this post so the announcement thread wont be filled up with subjects
![]() Nice info kris
09-18-2005, 10:52 AM
What's the speed differance between the R888 and the T1R in corners?
09-18-2005, 11:59 AM
mux213 Wrote:Split this post so the announcement thread wont be filled up with subjects Cool Mux ! I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-18-2005, 12:00 PM
Kir Wrote:What's the speed differance between the R888 and the T1R in corners? Kir: T1-R is a high performance STREET tire. R888 is an R-rated racing tire with thread. Differences" should" be A LOT ! Although i dont know yet. Kris I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-19-2005, 09:54 AM
These Toyo are awesome. They have better grip as racing slicks!!! We are racing on kart tracks (we don't call it so, but I think its AutoX). I use GY Eagle F1 GSD3 - we were very competitive until one of our competitors bought them. Now we are 3-4 seconds behind. Even in wet (F1 very good on wet surface).
09-19-2005, 10:38 AM
What are the specs on spring you are using?
My konis when set on soft seting could not damper enough 8kg/mm coilover springs so car would bounce a lot. Drifting - best fun you can have in your car with your pants on! |
| Trackday with my 86 at mornay track | makkuro | 2 | 6,834 |
04-27-2019 03:44 PM Last Post: makkuro |
| Wheel alignment settings for the track | Martynas | 9 | 17,240 |
11-23-2016 02:10 PM Last Post: Martynas |
| Grip/ Proffrsional Track Coilovers | hachirokkos | 15 | 25,398 |
10-15-2016 08:26 PM Last Post: NoHachi |
| AE-86 Track/Race car Spoiler/GT Wing Size and shape | hachirokkos | 5 | 14,524 |
11-26-2015 04:24 AM Last Post: asyrigos |
| Grobnik track day - AE86 inside | ZaX | 2 | 8,064 |
11-17-2011 02:57 PM Last Post: ZaX |
