Starter problems
04-17-2005, 10:48 AM
Starter problems
Did you try bridging it? (direct wire from battery to small terminal on starter). As I said before, I had this problem many times over, and if you only hear a clicking relay then you probably have a loose or broken wire somewhere. You can easily check by taking off the oil filter (if you still have the bottom exhaust heat shield, otherwise you can probably see what your doing anyway).
I really cant understand this "it doesnt work so the part must be changed" attitude. I would probably have wasted 4 perfectly good starters if I did this everytime I couldnt start my car. So far I've had starter wires come loose, immobiliser failure, and when I just bought it bearing failure (it did turn over a little bit then). These days I've taken out the immobiliser, have new bearings in the starter and my engine fires up on the second revolution of the starter engine. FABRICA MI DIEM, PVNC! |
04-17-2005, 12:33 PM
Starter problems
You need to spend 200 kr and fix your starter... I'm not sure what the parts are called but I can show you pix later
04-17-2005, 02:57 PM
Starter problems
... when mine didn't start it was the wire i wiggled it around a bit and it would start the wire is really small and thin ....
04-17-2005, 03:10 PM
Starter problems
wht not spray lubricants on it.... keehehehe jk only
![]() FBH(fucking big hammer)heheheehehehe..... :mrgreen:
04-17-2005, 03:44 PM
Starter problems
This is what you need:
04-22-2005, 09:48 PM
Starter problems
I had that problem on my AE82... the problem was starter selenoid switch [i think thats whats caled]..
I couldn't find a new one, so I disamble old one and olied it... it works for now [5 months]... |
08-31-2005, 08:26 PM
Starter problems
Changed the topic title and made it a sticky.
I suffer from the same problem at the moment. Battery fully charged, all I hear is a click and 1 out of 10 times it makes about a half revolution. I guess it is not a loose connection but something with the starter. Anyone got a good pic to show me where to apply the BFH?
09-01-2005, 07:20 AM
Starter problems
Look into my project, I had a problem with a starter too...
The common problem on the starters is, that the B+ contact gets galvanised during usage (the pic of galvanised contact is shown there). So the electric contact is poor - the consequence is that only few % of the current flows, so the starter doesn't have enough power to turn the engine or it turn's it just a few times... The other case is that the pinion doesn't return when the car starts. A friend of mine dissasembled and changed contact, as his department in the company produces starters ![]() Regards Andrej |
09-01-2005, 09:45 AM
Starter problems
Thanks! I'll apply the BFH today and see if it helps. (first aid)
I'll probably replace the contacts anyway, do you have the partnumbers of the contacts? And how hard is it to replace them? Do I need to do anything special to remove the starter? (e.g. prevent oil leakage) 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
09-01-2005, 10:25 AM
Starter problems
There are 2 ways of taking the starter of banpei:
1: least stressfull method, more expensive: detach exhaust manifold to make room to get to the starter, then just loosen the 2 bolts and disconnect wiring. 2: Method I used (on the older type starter): Get under the car, take off the small metal heatshield that's bolted to the starter engine. Try to disconnect wiring as far as possible, loosen bolts holding the starter in place (You can reach one from under and one from above the car). Now with the starter loose, you can manouver it out between the exhaust manifold and firewall. I've used this method 3 times, it is a pain to do and it will leave some wounds on your hands before your done, but you will save on the cost of exhaust gaskets. FABRICA MI DIEM, PVNC! |
| Big wheel problems | gh0st | 16 | 15,137 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,914 |
| AE86 starter options | max_ae86 | 12 | 37,972 |
07-28-2019 08:17 PM Last Post: harkes |
| Problems Mintex M1155 pads | Dino86 | 9 | 13,034 |
07-04-2017 11:22 AM Last Post: totta Crolla |
| 16v Bigport fuel problems | Rascal21 | 1 | 6,471 |
07-04-2015 01:00 AM Last Post: jondee86 |
![AEU86 AE86 - Starter problems [Image: AEU86 AE86 - Starter problems]](https://www.aeu86.org/sticker-banner-468.gif)
