| Author |
Message |
Dorito86 Moderator
Joined: 02 Nov 2004 Posts: 1135 Location: Sparta, Greece
1978 Austin Mini
Posted: Thu Mar 17, 2005 1:27 pm Post subject: Suspension modification |
It would be nice to have a sticky topic with people's feedback on what improvements will make the AE86 handle properly. So far information is spread everywhere around this forum making it hard to trace.
Obviously I'm not talking about details such as spring rates or rebound settings. These should be chosen by the driver depending on skill, car use, etc. I am more interested in certain issues that I have still not clarified in my mind like
Are adjustable 4-link rods necessary when lowering the car? Why? What will the difference in car handling/feel be with and without the upgrade? I remember reading something about the rods sitting at the "wrong" angle after lowering the car, but how does that affect handling?
How will difference in ride height between front and rear affect weight distribution? I'm guessing but wouldn't a lower front end mean more weight on the front tyres = more grip =less grip for the rear = oversteer?
I realise these may require comlete writeups from the more techniocally knowledgeable of you, but still they would be nice to have
| Back to top |
Mux213 Site Admin
Posted: Thu Mar 17, 2005 1:40 pm Post subject: |
Dorito,
Well we need some way to manage that, especially when subjects get asked in parts its hard to get a sticky going.
I'll make this thread a sticky if people promise to post good information about suspention here!
_________________ Greetz,
No more hachi
| Back to top |
alimonos Bunta
Joined: 10 Jan 2005 Posts: 2521 Location: HPEIROS - GREECE
Posted: Thu Mar 17, 2005 1:53 pm Post subject: |
great thoughts Dorito!
We need these info gathered in one topic !!!
Please help us not so well technically aspirated guys...
_________________ AE86 FANATIC!!!
| Back to top |
jamiemirror Bunta
Joined: 04 Jan 2005 Posts: 1795 Location: Sofia, Bulgaria
Posted: Thu Mar 17, 2005 3:39 pm Post subject: |
Please, add all these to "Articles" - I think this is the "Articles" section about.
| Back to top |
ae86 Ryousuke
Joined: 02 Oct 2004 Posts: 170 Location: n-b netherlands
Posted: Wed Apr 06, 2005 10:26 pm Post subject: |
[Ivanhoe translation service:]
Tip for the front shocks: for some firmer dampening you can remove the original shock inserts (if you still have those) and refill them with 5w30 engine oil and reassemble..they should be a lot stiffer after that.
tip voor de voorshockers. ja in het nederlands:P
voor wat meer demping (zoals koni's) demonteer de originele dempers en laat de olie eruit lopen.
hervul ze met een 5w30 motorolie, en zet ze weer in elkaar.
Je hebt nu flink stuggere dempers, ik rijd zo al jaren rond .
ae86
| Back to top |
alimonos Bunta
Posted: Wed Apr 06, 2005 10:48 pm Post subject: |
Nice try ae86 but only if we could understand that language...
| Back to top |
Tofu @ AE86 Iketani
Joined: 28 Oct 2004 Posts: 45 Location: Sintra, Portugal
Posted: Sun Apr 10, 2005 9:51 pm Post subject: |
...as for mod´s....
my car has:
sparco springs (-30mm) discontinued
koni sport shocks (70% hardness adjusted)
prothane polyurethane bushings
front and rear strut braces...
t3 adjustable camber plates
t3 roll center adjuster´s (rca)
...i thing these are the basic mod´s that improve the car handling dramatically ....of course, associated do wider wheels and good grip tires....
in my case, konig rewind´s 14x7 -9 ....
| Back to top |
KristianAE86 Moderator
| Back to top |
Posted: Sun Apr 10, 2005 11:03 pm Post subject: |
my rear set up...
KONI yellows set to 85% of max, twin swaybars
_________________ I´m sorry sir, your planet has been sceduled for destruction
| Back to top |
alimonos Bunta
Posted: Mon Apr 11, 2005 1:11 am Post subject: |
Hey guys when the car is lowered is it necessary that we install both the items i show in the picture? If yes or no please explain and name these items please...
| Back to top |
Widar Bunta
Joined: 07 Sep 2004 Posts: 1820 Location: Borås, Sweden
| Back to top |
alimonos Bunta
Posted: Mon Apr 11, 2005 1:20 am Post subject: |
Widar the RCAs are used only with adjustable coilovers right?
| Back to top |
Widar Bunta
Posted: Mon Apr 11, 2005 1:22 am Post subject: |
| alimonos wrote: | Widar the RCAs are used only with adjustable coilovers right?  | Nope, they should be used with any extensive lowering to get the lower control arms to their right position.
_________________
| Back to top |
alimonos Bunta
Posted: Mon Apr 11, 2005 1:23 am Post subject: |
Thanks a lot widar i 've found the answers in the T3 site...
| Back to top |
alimonos Bunta
Posted: Mon Apr 11, 2005 1:24 am Post subject: |
And Widar they are rrrrreally beautys...
How much for them though...???
| Back to top |
Widar Bunta
Posted: Mon Apr 11, 2005 1:31 am Post subject: |
| alimonos wrote: | And Widar they are rrrrreally beautys...
How much for them though...???  |
Fronts are $725 and rear $600... Alot of money, but good stuff for them!
_________________
| Back to top |
The Doctor Bunta
Joined: 18 Sep 2004 Posts: 2220 Location: Goirle, The Netherlands
Posted: Mon Apr 11, 2005 1:40 am Post subject: |
that's quite a lot of money.
BUT here in holland there's a company that can deliver coilover kits (or make them from your shocks, they place a tube on the shock with thread on them and some other stuff to make it complete) for 600 euro or so.
NOT an ideal way imho, but a friend of mine had to do it (because his Celica struts wouldn't fit to his Starlet without them)
_________________
| Back to top |
alimonos Bunta
Posted: Mon Apr 11, 2005 1:55 am Post subject: |
1325$ ??????
plus shipping costs....
too expensive to be ours my dear... (talking to my car men)
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4819 Location: Netherlands Z-H
Posted: Mon Apr 11, 2005 11:22 am Post subject: |
Then make them yourself...buy loose coilovers from paradise racing, shorten your struts and rest the coilovers on new small perches (those coilovers are aluminium I think, welding them on directly is probably not a good idea). You can choose whatever shock you like, KYB AGX, Koni yellow, Tokico HTS...you name it, as long as it's short stroke. Get the strut sandblasted and anodised/painted and it will look nice enough.
'81 poor guy with a money-pit
| Back to top |
Dorito86 Moderator
1978 Austin Mini
Posted: Mon Apr 11, 2005 4:09 pm Post subject: |
@Ivan: It obviously makes sense financially, but there's another issue. Safety. I don't have a fully equiped garage or access to welding equipment. And even if I did, it would be foolish to start my welding career on my front struts. So I have to take them to a suspension-shop. But how can I trust that they are well built and I won't end up in the gravel (or even a tree) with on collapsed strut? So T3 suddently starts to look like a cost-efficient solution
| Back to top |
Ivan141 Moderator
Posted: Mon Apr 11, 2005 4:44 pm Post subject: |
T3 dont do superhuman welding, so you can probably find someone that can make a very strong weld just like theirs. Why should you have to go to a suspension shop, other shops that do work on metal should be perfectly able to cut the struts to a certain length of your choice and weld them back together.
I can understand your point of view though..
| Back to top |
jamiemirror Bunta
Posted: Tue Apr 12, 2005 10:37 am Post subject: |
The original strut housings are made from seam tubes. So your welding (professional welding, don't start teaching yourself on struts) is strong enough. But there is another option - replace the whole tube and use only bottom part of assembly. Exotic - but possible. I chose the first option and now my housings are shortened and welded clear and strong
| Back to top |
Ivan141 Moderator
Posted: Tue Apr 12, 2005 12:36 pm Post subject: |
There are coilover sets for sale that have threads for the nut at the end. If you buy those you only need to cut the strut a certain amount and weld the coilover on. They are more expensive though..
| Back to top |
WeRz Iketani
| Back to top |
Mux213 Site Admin
Posted: Mon Jul 25, 2005 8:49 am Post subject: |
Werz,
Short stroke means that you have a shorter shock obsorbers then stock. The stock ae86 shocks don't have enough travel left when you lower your car because of their lenght. Especially with gas struts this becomes a problem. Using normal sized ae86 shocks with stiffer springs will also mean that your spring comes loose when your car comes offf the ground and that is an MOT failure, atleast here in holland.
The solution is to use shorter shocks (hence the name short stroke) like AE92 shocks. You need to modify the struts by removing about 4cm out of the struts so the shorter shocks will fit. This way you can lower the car alot more and or install stiffer springs without getting into trouble.
Read this for more info:
http://www.club4ag.com/faq%20and%20tech_pages/S...%20Conversion.htm
No more hachi
| Back to top |
