Steering Rack bushings
03-10-2010, 12:26 AM
hello ,
Do you have problem with your steering rack bushings ? Got them changed 5 times now . Each time passing Mot control , i'm rejected for that reason . Does anyone knows if stiffer bushings exist? I saw this on Techno Toy Tuning , but don't know if it's what I need (i have manual rack) http://www.technotoytuning.com/productdetail.php?p=112 Anything else to reolace stock bushings ? Regards Filh Filh Save the RWD cars |
03-10-2010, 08:30 AM
AE86 FANATIC!!! |
03-10-2010, 08:38 AM
filh! THE bushing you linked is an adapter bushing for using manual rack in an originally power steered car (the rack housings are different in size -> different mounting on the front member, so they are not interchargable by default)
prothane has the bushings you need. red urethane just like any other bushings for the 86 by prothane. ajps also good.
03-12-2010, 10:45 PM
Many thanks to both of you .
On Ebay, AJPS bushing is no longer listed . Found Prothane here http://cgi.ebay.com/ebaymotors/ws/eBayIS...0241174887 Prothane ref is 18-702 Also same as Toyota MR2 MkI Thanks and regards Filh Save the RWD cars |
| Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 10,804 |
| Quaife quick rack | totta Crolla | 19 | 28,522 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
| Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 54,964 |
| Poly vs OEM bushings | Jezza_hr | 5 | 10,450 |
05-14-2014 11:28 PM Last Post: Jezza_hr |
| Play in power steering rack help | phill 92 | 5 | 9,017 |
10-25-2012 12:01 PM Last Post: allencr |
