Ricks project AE85 (Back together with dyno results)
06-20-2009, 08:36 AM
Post: #91
ok ...get that part but what has me stumped is....the intake part of the sc right side ...originally sat the throttle body....how would the piping work?
oem air filter -2- throttle body -2- s/c -2- i/c -2- intake manifold.....right? you have it air filter -2- s/c -2- i/c -2- throttle body/manifold...? does it work the same? that's interesting......i never seen it done like that.... do you still have the abv or can you completly eliminated? ![]()
Reppin' the old skool....Drive Drift Dream ![]()
06-20-2009, 12:59 PM
Post: #92
Basically mine is like a turbo setup but with a supercharger instead.
I don't use the factory ABV but I do use an aftermarket blow off valve which vents pressure between gear shifts etc.. and it also acts as a bypass at idle or when the supercharger is not running to allow the motor to breathe. The BOV is controlled by the vaccum/pressure inside the intake manifold. The BOV is not so much used to stop compressor stall as you can't stall the supercharger rotors because they are driven off the motor its more to stop intercooler hoses blowing off when shifting between gears or when deaccelerating. The factory setup is like you said: air filter, throttle body, s/c, i/c, intake manifold. ![]() Corolla Levin SR 1984 AE-85 (Project car) Corolla Runx Z 2002 (Runabout) |
07-03-2009, 12:48 PM
Post: #93
A bit more progress.... I gave up on trying to get a brand new window, ended up getting a good condition second hand one.
Since the last update I have had all the glass installed, had the wheel alignment done, installed a brake bias adjuster, installed the seats and harnesses. The starter motor also failed so I rebuilt that and completed a few hundred other jobs which I wont bore you with. I drove it the other day to get its certification and it passed..... no problems what so ever, I was well happy with that BUT as with most projects they are never really finished........they are forever ongoing. From the few times that I have driven the car it seems that I will need to change the clutch and flywheel, I am curently running a 4age 20v which is too light. There are still a few small jobs yet to be done but thats by the by, atleast its looks like a car now. ![]() ![]() ![]() ![]() ![]()
07-03-2009, 02:01 PM
Post: #94
superclean.btw I posted the front window article number for the Pelinkton wind shields. its 8249ABL Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
07-03-2009, 04:30 PM
Post: #95
What an awesome car! You have done such a good job with it. Keep it up.
07-03-2009, 09:37 PM
Post: #96
You are the man Rick. The car looks awesome, good work. That lip looks pretty sweet, are you happy with it?
07-08-2009, 01:35 AM
Post: #97
Nice example Rick,
Whats the comfort like in those racepro seats? They look like the wider base ones? I'm thinking about getting a set of them from trademe but haven't sat in them before. Cheers Phil 1985 Toyota Levin Hybrid F20C Conversion ~~~~~~~~~~~~~~~ http://www.jspecgroup.com |
07-08-2009, 10:17 PM
Post: #98
Excellent work sir.
another one saved.
Regards Ian. |
07-10-2009, 07:17 AM
Post: #99
hachirokuGTV Wrote:You are the man Rick. The car looks awesome, good work. That lip looks pretty sweet, are you happy with it? Yeh the lip is all good, I ended up repainting it to suit my bumpers. Tofu Wrote:Nice example Rick, The seats are pritty good for comfort, however I havent spent that much time in them, time will tell. Yes they are the wider ones, Iam pritty slim and there was no way I could fit into the other type, you would need to test fit before buying any. ![]() Corolla Levin SR 1984 AE-85 (Project car) Corolla Runx Z 2002 (Runabout) |
08-06-2009, 08:29 PM
Post: #100
My car is now road legal.. yay ..
My car initially suffured from the dreaded 5500rpm power dip which I originally thought to have been caused by my light fly wheel, I have since changed the ECU to a spare one that I had and the few times that I have driven it since, it apears to have fixed the problem. I thought this was all to easy and wanted to get to the bottom of the problem so I opened up the faulty ECU to find two of the seven capacitors were leaking. Iam in the middle of replacing them and when finished I will swap the ECU's over again to see if that was the cause. I will also get the car dynoed soon to see how little power it has. I still have to finish off a few small jobs but really its more or less finished, I have just lots and lots of testing, suspension tuning etc to be done plus later on I have a larger pulley for it.. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
| Ae85 | Minidaxman | 4 | 6,065 |
04-20-2021 09:57 PM Last Post: banpei |
| time to get her back on the road.. | worholm | 4 | 9,577 |
01-21-2017 09:33 AM Last Post: worholm |
| AE85 Power! From 175HP 20v to 202HP F20 | 4000GT | 23 | 38,870 |
10-16-2014 02:53 PM Last Post: mad.matt |
| Sam's AE85 Conversion | Sambo | 2 | 18,204 |
05-20-2014 05:03 AM Last Post: Sambo |
| Stalkers daily AE85 - 7AGE | stalker | 32 | 57,401 |
12-28-2011 02:28 PM Last Post: stalker |
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://i44.tinypic.com/2n694xh.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://i40.tinypic.com/20itljq.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img39.imageshack.us/img39/4898/profilepick.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img190.imageshack.us/img190/7401/ud1.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img18.imageshack.us/img18/9184/ud2y.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img16.imageshack.us/img16/5936/dsc02971wwl.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img443.imageshack.us/img443/4941/dsc02959.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img190.imageshack.us/img190/974/dsc02958z.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img196.imageshack.us/img196/1033/dsc03072v.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img145.imageshack.us/img145/2300/dsc03071s.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img30.imageshack.us/img30/3172/dsc03075c.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img20.imageshack.us/img20/4184/copyofdsc03068.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img217.imageshack.us/img217/6251/copyofdsc03067.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img15.imageshack.us/img15/8379/copyofdsc03064.jpg)
![AEU86 AE86 - Ricks project AE85 (Back to...o results) [Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]](http://img40.imageshack.us/img40/7047/copyofdsc03063.jpg)
