Jimmi's Trackday car
04-21-2009, 02:13 PM
Well I'm converting my 3 door AE86 into a trackday car. I'm not a good racecardriver (I'm too damn carefull), but I think its funny to build cars. I have done a few engine conversions on FWD Toyotas and done a few engine rebuilding and tune ups. I'm educatet Toyota car mechanic and have worked with Toyota for 10 years now.
This will be my first actually racecar build and I try to do it all by myshelf.
The basic car was importet from Switzerland, as the Danish one are too rusty. Unfortunally this one also have a bit hidden rust, but not too much.
In fact, this car will not be a 100% racecar because it should be able to run on the streets, as the trackday rules i Denmark said, that the cars have to run with numberplates and therefore has to be streetlegal. The car have to pass MOT test every 2 years, so I have to build it, so I can change it in a few time :wink:
The original idea was to build it, so I can make it 100% stock again in a few days, but this will be too difficult so I change the plan.
I will also try to build the car after the FIA and DASU (Danish Automobile Sports Union) rules, so the car can be converted to a 100% racecar or rallycar some day.
With all that in mind, I can start to make it happen Hurray!
[Image: AEU86 AE86 - Jimmi's Trackday car]
I did't have any dry ice, so I took some regular free snow. Well the tempereture in the workshop was only 1,5 degrees celcius.
I only used this tool and it took me about 4 hours.
I removed almost 20kg.
Some of the hidden rust
Took this part from a EE80 Corolla, fits perfectly, but the corners dont.
I borrow this piece of tool. And spotwelded the roof, dorholes and the right rear fender.
I also spotwelded it a bit
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
04-21-2009, 02:37 PM
Very nice work.
Koukis - Red, Silver/Gray,
Cool project!
Good luck Thumbs up!
04-21-2009, 02:40 PM
Phase 2, allmost 8 months without doing anything. It have also been winter and I have no heat in my workshop.
I hammered up the fenders and sealed it.
This is with 7x15" ET -5, and the wheel don't hit. The spring stop is removed. I think I can run with a 7½" or 8" ET 15 with the car not so low.
It was time to get it up
I have to repair the old parts, because U can not buy them anymore.
I will try to make a new frame here so the lower 4 links can be more stiff.
Its done in a regular 0,8-0,9mm sheet metal and bended in hand between to pieces of solid metal.
The finish part
Cars I have owned:
04-21-2009, 03:49 PM
Here's some of the stuff I have collectet.
TODA 4-2-1 header. It only fits RHD and my car is a LHD, so I have to make a few adjustment to the steering rack.
Whitelines, pretty rare here in Denmark
Sparco stuff
Quaife quick steering rack
TODA 200mm upratet clutch
Slightly used TEIN suspension.
18L safetytank
KaaZ 2way LSD
Reinforced enginemounts, and it also lower the engine 10mm
TRD Carillo Formula Atlantic con rods with 19mm pin
Here's my new baby, fully portet and flow testet smallport head. There is maked room for high compression pistons.
The porting and flowing is done by a motorcycle tuner and he actually put material on around the valveguides and the guides are changed to a thinner type. The valves are polished and I think he did a 3 angle valvejob also. The guy I bought it from, used it on his rallycar. He claimed that the engine produced 196hp and 190nm @ crank with custom made 288' duration and 8,0mm lift cams with stock buckets and springs.
Cars I have owned:
04-21-2009, 05:53 PM
Jimmi The Kid Wrote:[Image: AEU86 AE86 - Jimmi's Trackday car]
This looks very nice! I wish I would've thought of doing the ones on my car the same way.
BTW, I used to have a RWD Starlet with a 4K, 300deg cam, bike carbs, etc. One of the lower link brackets got torn off the car on a hard acceleration. Big Grin Bracing the lower links certainly is a useful thing to do.
03-03-2012, 09:55 PM
Its bin a sloooooow build, but now I got some news Hurray!
Sandblastet the body
Painted with 2K Epoxy primer
Made some FPR copies Smile
Ready for paint
Cars I have owned:
03-03-2012, 11:58 PM
Made some FPR copies --->im intersted for a set.... Thumbs up!
rear wheels cant be with this ofset mate...-5 offset with spacers maybe??
03-04-2012, 10:51 AM
Petros AE86 Wrote:Made some FPR copies --->im intersted for a set.... Thumbs up!
I can't not promise I can make more of them, but I have though about it.
Yes, I think your right about the offset, but we will see Smile
Cars I have owned:
03-04-2012, 08:46 PM
The car back from the paintshop Hurray! Hurray! Hurray!
Cars I have owned:
  Project: My new trackday toy (56k beware!) Morten 88 107,052 02-25-2010 01:44 PM
Last Post: Morten
  MCNSPORT.com AE86 4ag Trackday project! MCNSPORT.com 5 18,376 09-17-2009 08:26 PM
Last Post: MCNSPORT.com
  MCNSPORT.com AE86 4ag Trackday project! MCNSPORT.com 4 11,519 06-01-2009 10:09 PM
Last Post: robokill
