ITB from bike engine ?
04-02-2009, 04:17 PM
dr.occa Wrote:the only difference is available intake manifolds. they'll have to be custom fabbed.
i've got several bike carb projects in the oven using varying size carbs and ITBs (w/ megasquirt).
That's exactly what i am interested in, ITB, EFI and megasquirt (or something similar).
Are these project presented somewhere?
regards
04-02-2009, 05:05 PM
Uzelac Wrote:Mate, your posts are real informing but aint' answers on my question Smile. Perhaps i wasn't specific enough, but i'm interested in ITB's with electronic fuel injection and MAP is important in that configuration.
regards
as for running a MAP setup, as someone may have mentioned before, w/ a stand alone ECU, MAP or alpha-n(TPS) are easily possible depending on your cam profiles.
unfortunately, i'm always pressed for time so i rarely document the process of my projects. i'll usually just post up the final product. maybe this time around i'll give it a shot.
here's somewhat of a process i've begun documenting on www.86garage.com.
[Image: AEU86 AE86 - ITB from bike engine ?]
"Strictly All Things 86"
04-03-2009, 12:55 AM
Something like this....
[img]http://lh3.ggpht.com/_APKI3b0oh_A/SdUl0mGHLeI/AAAAAAAABLo/yXN-xRUPk78/s288/DSC05023.JPG"[/img]
Honda CBR 1000RR 2006 ITB with dual injectors, tps ... (43mm body, not sure about injectors)
....would be ok ?
+ Megasquirt
+ MAP
+ some other stuff ?
04-03-2009, 05:05 AM
Silver Tops throttles goes for around 200 euro
while the black tops goes for another 300 euro
shipping depending where your country is.
04-03-2009, 06:00 AM
Uzelac Wrote:Something like this....
Honda CBG 2006 ITB with dual injectors, tps ... (43mm body, not sure about injectors)
....would be ok ?
+ Megasquirt
+ MAP
yep, those should be quite "adequate" to say the least.
04-03-2009, 09:27 AM
panda_tureno86 Wrote:Silver Tops throttles goes for around 200 euro.....shipping depending where your country is.
Bike's ITB's are more avaliable, much cheaper and often comes with injectors/tps/map...
This Honda ITB is 100€ as seen on that picture, and there is no shipping since everything can be found locally Smile.
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 10,698 10-30-2013 11:18 PM
  Stock Bigport Engine + ITB?s?! pack 36 63,626 06-15-2013 07:19 AM
Last Post: jondee86
  Need engine,any engine Apolan 25 26,946 10-29-2006 06:55 PM
