Starter problems
02-08-2006, 09:58 PM
Post: #41
Starter problems
delange Wrote:StudeBaker Wrote:I have a simular problem...have had the same problem, tried testing alot of things (map-sensor,ECU,electrical wiring,...) eventually it was the fuelpump that didn't worked so good, it didn't make enough pressure while it was working & sometimes it worked great and after a few km it stopped thanks, yeah, my fuel pump is still stock, maybe i should try a new one! it´s just as you say, sometimes it stops, in every situation... slow driving or just flat out... i will try this! |
04-09-2006, 09:28 PM
Post: #42
Starter problems
I have a problem with engine starter, but not with starter but with part which move starter gear into flywheel and make a contact betwen + pole of batery and starter motor, you know, smal piece which is screwed for starter.
Do someone know from which Toyota engines I can fit in starter or just part that moves starter gear? 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
04-10-2006, 09:10 PM
Post: #43
Starter problems
Today I buy a new one, 25 €.
Put everything in place, and a hachi is running again. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
04-10-2006, 09:45 PM
Post: #44
Starter problems
Kas Wrote:Today I buy a new one, 25 €.Congrats ![]() Do you have a partnumber? Might be a good one if others are searching for it.
04-15-2006, 08:30 PM
Post: #45
Starter problems
No, sorry.
I buy part in http://www.jcauto.pl/ Just bring old one, and salesman go back, and do a search and that is it. They are very good with prices here in Croatia and we also have some discount. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
03-24-2009, 12:04 PM
Post: #46
Starter problems
Hey thought I will share with you guys about my problems with the starter in my hachi.
same deal, old and worn out. the problems that I had before that was it didnt want to start after it heated up... and tried all the banging and bashing and clutch starting. It lasted for another month before the starter really died on me. I turned the keys and there was NOTHING. So I took the started out and had to change the "piston" inside the starter. Basically its the gear that spins your flywheel around won't go back into place. Anyway, had a rebuild done for HK$800, thats including parts and labour. After rebuilding the starter, it starts fine for another week. Then the same problem happened again. So it turns out that the hachi is not getting enough EARTH. Especially from the iginition barrel cos its pretty old and worn. Anyway, had some relays put in and some more earthing wires that I made up myself. Starts fine everytime now. |
05-01-2014, 09:38 AM
Post: #47
Starter problems
(03-24-2009 12:04 PM)panda_tureno86 Wrote: Hey thought I will share with you guys about my problems with the starter in my hachi. do u want the starter problems end for ever? relocate the starter and use a 4afe starter 4age 16v to FR 20VT |
02-04-2015, 10:34 AM
(This post was last modified: 02-04-2015 11:13 AM by harkes.)
Post: #48
Starter problems
I had the same problem - same symptoms recently...
Pulled the starter and found as shown on the pics below. Cobber plate is out of concentricity and has been rubbing on the solenoid. Realigned - car started up immediately. |
02-08-2015, 11:31 PM
Post: #49
Starter problems
Sometimes the ignition switch becomes bad. (That was the problem of my 86).
By adding a relay between the starter and ignition switch it could solve the problem of clicking. |
02-09-2015, 10:11 AM
Post: #50
Starter problems
Good tips here, although I'm not too sure I would recommend a starter relocation.
| Big wheel problems | gh0st | 16 | 15,642 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 5,033 |
| AE86 starter options | max_ae86 | 12 | 38,503 |
07-28-2019 08:17 PM Last Post: harkes |
| Problems Mintex M1155 pads | Dino86 | 9 | 13,241 |
07-04-2017 11:22 AM Last Post: totta Crolla |
| 16v Bigport fuel problems | Rascal21 | 1 | 6,586 |
07-04-2015 01:00 AM Last Post: jondee86 |
![AEU86 AE86 - Starter problems [Image: AEU86 AE86 - Starter problems]](https://www.aeu86.org/sticker-banner-468.gif)
