The A6 Celica/Carina topic
05-27-2008, 12:44 PM
Post: #311
Great find and thanks for sharing it with us! Thumbs up!
Too bad they crashed one of the Carinas... Blush
[Image: AEU86 AE86 - The A6 Celica/Carina topic]
11-17-2008, 11:26 PM
Post: #312
really nice carinas, I didn“t realise that those new Tongue ones also have so nice figures.
Almost make me want one, sad I already have too many other models, but it sure nice to look these great ones here Cool
blacktop beams 3S-GE carina
02-10-2009, 05:08 PM
Post: #313
Hi there,
Can somebody tell me, what could be the factory tire size of a TA62 coupe? I'm attaching a pic below, those wheels were on my car, when i bought it.
I think those are stock A6 Carina rims and tires. Their size is 175/70R13.
A friend of mine works for a Toyota dealer, and i asked him to look for the stock tire size in his program. He told me, that the progam say the factory size is "185/70HR13" and "165SR13".
I'm searching for the CelicaSupra P-type rims, and hopefully i have found a set for sale nearby (i'm going to look at it tomorrow). It's 7" wide and as i read, the minimal tire width is 195 for a 7" wide wheel. I dont know which tire would i choose to aviod the known problems regarding the mismatching rolling radius...
Thanks
Andrew
AndrewGL
02-11-2009, 01:29 PM
Post: #314
From experience I know my ae86 did not have any rubbing problems with 195/55 R14 on those CS rims.
The L-type 15 inch I currently have on my Carina do have a different offset (+20 instead of +8 ) and don't have rubbing on the inside of my Carina with 195/60 R15.
The 7 inch should have 1 millimeter less clearance on the inside and should be extending 2,5 cm on the outside. I can mesure if 2,5 cm should give you enough clearance on the fenders. Smile
I know from experience that 185/60 R14 does fit on those 7J:
And 165/50 R14 is also possible and should give you a nice stretched look. Thumbs up!
02-11-2009, 02:02 PM
Post: #315
aah, someone kicked this topic JUST in the right time!
WANT!!!!!
02-11-2009, 03:00 PM
Post: #316
http://link.marktplaats.nl/223128402
And then do a headlight conversion and add some nicer rims? Dumb question
02-12-2009, 12:07 AM
Post: #317
waaay to expensive, otherwise i'd have it allready! Tongue
plus it has a live axle, instead of IRS Tongue
02-12-2009, 12:37 PM
Post: #318
banpei Wrote:From experience I know my ae86 did not have any rubbing problems with 195/55 R14 on those CS rims.
Its ok, but how (i mean from which database) do you know the diameter of the wheel? Which size did you considered as base, to choose a correct wheel size in 15"?
Andrew
AndrewGL
02-13-2009, 10:34 PM
Post: #319
@AndrewGL: My Carina featured the 165 R13 combo without any height indication. I measured them and came to the conclusion they had to be about 165/83 R13. Then I used a tire calculator and matched 165/85 R13 with the 185/60 R15 combo to maintain the same size.
@The Doctor: Live axles rule! Tongue
02-14-2009, 01:33 AM
Post: #320
no, IRS rules, you get free camber when you grind the springs in halves! ;D
  Another rusty old carina. roman 8 19,204 08-20-2007 12:56 PM
Last Post: roman
  Amazing -musseum ready- Celica nmwisima 26 35,080 03-13-2006 12:42 AM
Last Post: The Doctor
  ST185 celica evo 500 SekiguchiUeno 2 6,766 02-25-2006 08:53 AM
  Check out that old CELICA!!! nmwisima 12 19,097 07-10-2005 10:09 AM
