AEU86.ORG Shop final sale
06-17-2008, 09:08 AM
Post: #51
Finally mounted the Mintex Brake pads. The surface was quite a bit smaller than the original brake pads. I thought how can these bite better... but after i mounted them and braked a few times it started to bite. If they are hot they really bite good man! Thanks!
11-03-2008, 11:24 PM
Post: #52
Time to bump this one again...
Stock and prices: - 1 Toyota RNP 4.7 430 euro ![]() - 1 Solid spacer 65 euro [s:cf32d884a8]- 1 full set of KONI AE86 370 euro[/s:cf32d884a8] (reserved) - A bunch of oil filters 4 euro - 1 Tein camber plates 200 euro - 2 AEU86 camber plates 125 euro 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
11-04-2008, 09:14 AM
Post: #53
Do the TEIN/aeu86 camber plates fit the AGX KYBs ?
How many are the oil filters ? OEM ones ? AE86 FANATIC!!! |
11-04-2008, 03:18 PM
Post: #54
How high will be car on Koni's and Apex springs?
I think I can take Koni's but I need to have buyer for my Tokico's first They are after renovation - now like new. AE86! love love love! Hankiewicz Rally Team |
11-04-2008, 09:51 PM
Post: #55
@Whitepoint: The Apex springs lower the car about 3 cm, but the konis won't fit the front struts anymore: Mux cut them to convert them to longstroke. Or did Mux also gave you the original struts with the car? Also S.K. pm-med me about the Konis, so he has the first option.
@alimonos: AEU86 camberplates are based on the TEIN design. They should be universal to almost all shocks. You will only have trouble with Konis which have different mounting nut. Dunno about what brand the the oilfilters are, but they are not OEM Toyota... I thought I promised 2 of them to Cavey, so there should be another 6 available. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
11-04-2008, 09:57 PM
Post: #56
Did not understand what you mean
11-05-2008, 06:33 PM
Post: #57
I mean that Mux converted the car to short-stroke (less length on dampening the car). The Koni's are long stroke shocks so unless you mounted normal front struts on the car they won't fit.
I see in this pic the coilovers are still on the car:
11-05-2008, 11:24 PM
Post: #58
i've got koni's, and long stroke housings, if you want to swap!
11-06-2008, 12:10 AM
Post: #59
Doc,
Don't you have springs that match to go with it? You might be able to do a full swap with Whitepoint. Paul, as Banpei said, the struts on my hachi are shorter then stock so the koni's won't fit in them, also the height adjust system is not designed to work with springs such as Apex. You need original strut housing if you want to go back to such a system. I could be wrong but I believe this picture was taken when I still had a KONI/APEX setup:
11-06-2008, 12:36 AM
Post: #60
no springs anymore, i had an ebay coiloverkit, but i happily buy a set of springs and swap your suspension with mine!
front and rear AE86 koni yellows, long stroke (really comfy when switched to soft). "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
| OISHI New online shop | JonnyAE86 | 28 | 39,802 |
01-22-2013 06:21 PM Last Post: JonnyAE86 |
| AE86 5.375 Final Gears - TRD | club-86 | 20 | 27,227 |
01-25-2011 02:05 PM Last Post: Bean |
| ZENKY RACING - 5.375 Final Drive for Toyota AE86 | crxman | 41 | 56,489 |
06-05-2010 08:33 PM Last Post: crxman |
| AEU86 Shop | Mux213 | 293 | 386,525 |
02-27-2008 07:17 PM Last Post: Guillaume |
| AEU86 SALE | Mux213 | 7 | 11,314 |
12-19-2007 02:25 PM Last Post: Mux213 |
![AEU86 AE86 - AEU86.ORG Shop final sale [Image: AEU86 AE86 - AEU86.ORG Shop final sale]](https://www.aeu86.org/files/to/toyota_4_778_rnp_142.jpg)
![AEU86 AE86 - AEU86.ORG Shop final sale [Image: AEU86 AE86 - AEU86.ORG Shop final sale]](https://www.aeu86.org/sticker-banner-468.gif)
