How To: DIY Short-Shifter
11-12-2004, 01:45 PM
Any of you more technicaly inclined people can help with a write up on how to make a short throw shifter? Would be very appreciated
11-12-2004, 01:53 PM
i have made 2 as of now.
want the entire list of how to do one ? NO problems. I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
11-12-2004, 03:05 PM
please, I would like to know also
You have by far the ugliest hachi on the nicest rims in the world -Mux213 |
11-12-2004, 08:47 PM
Kristian,
I'm paying attention Regards Ian. |
11-12-2004, 09:16 PM
yeah, yeah we are still paying attentio
11-12-2004, 09:55 PM
step by step:
1: remove interiour around gearstick (shifter) 2: losen the 4 6mm (10mm tool) bolts that hold the rubber dust-protection-cover. 3: loosen the 4 8mm bolts that hold the gearstick to the gearbox. 4. lift up gearstick slowly in order to check if plastic cup at bottom of gearstick is loose. (replace plastic cup. about 5 Euro at Toyota.) 5: using hacksaw (metal-blade 1mm thick) cut gearstick 10mm above lower ball-joint. 6: cut metal tube of approximatly same diameter as gearstick to exactly 21mm lenght 7: lengthen gearstick using using MIG/TIG welder & after welding grind down welds to a minimum & reweld - this makes it stronger. 8: using upper gearstick mount - se picture take aluminum block in size 20x80x103mm, Place block below mount - drill the 4 8mm boltholes using 9/10mm drill. 9: using gearstick mount gasket (if not broken when removed) as a measurment (blueprint) take metalblock - measure the inner line & drill-out the center so that it copy´s the gasket. 10: make one more gasket using stock gasket as blueprint. 11: re-assemble 12: you now have 55% shorter throw to your gears. / .....Kristian gearshift mount... se below. I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
12-02-2004, 10:25 PM
new pics added
12-03-2004, 12:29 AM
nice one :-) don't understand it fully yet but hey will come in time
01-05-2005, 02:38 PM
A simplest way to short shifting :-)
01-05-2005, 02:49 PM
2 jamiemirro: To me it looks just like a cutted gearstick.
Kris has posted correct way to make short throw shifter for faster shifting. Drifting - best fun you can have in your car with your pants on! |
| TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 19 | 27,891 |
04-27-2024 10:04 PM Last Post: banpei |
| DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 24,292 |
12-21-2016 10:28 PM Last Post: ditn |
| Anyone running DIY Coilovers? | Rasteirinho | 8 | 17,290 |
11-19-2013 10:30 PM Last Post: totta Crolla |
| Were to find 4AG-ZE gaskets in toyota diy? | fax0815 | 17 | 22,098 |
05-28-2013 10:17 PM Last Post: ditn |
| DIY Coilover | sketchy | 8 | 16,625 |
04-01-2013 11:00 PM Last Post: sketchy |
