Can you convert your 86 back too the original state?
04-17-2022, 09:23 PM (This post was last modified: 04-17-2022 09:48 PM by gh0st.)
Hello everyone!
I'd like to know, suppose you convert your levin to a trueno. After a while you start to prefer the Levin look again. Can you convert it back, or will the bulkheads be too damaged for a reconversion?
Thanks!
04-18-2022, 01:25 PM
Shouldn't be an issue as long as you keep all the parts.
AE86 ex-daily
04-18-2022, 09:19 PM
The conversion requires the fenders, bonnet, headlamps and electric wiring to be swapped or adjusted. This means you don't need to damage the bulkhead (also known as firewall and this sits between the passenger compartment and the engine) to convert a Levin to a Trueno. So when you are bored from it you can easily swap everything back.
[Image: AEU86 AE86 - Can you convert your 86 bac...nal state?]
04-19-2022, 09:07 AM
As I believe gh0st wan't to make a initial D replica...
Don't you need to do some adjustments to the bulkhead when fitting a 20v?
04-19-2022, 09:40 AM
The only real modification you need to make from Levin to Trueno are the headlight brackets.
Those are spot welded on, and you need to drill them off to fit Trueno lights.
If you want to be able to swap back to Levin (sounds like a good idea), then I would just drill all the way through the spotwelds and put some rivnuts in place.
That way you can bolt the brackets back on later.
04-20-2022, 12:44 PM
(04-19-2022 09:07 AM)r.ave Wrote:  As I believe gh0st wan't to make a initial D replica...
The problem is the distributor of the 20v which is on the back of the engine. Getting a relocation kit solves this problem. A cheaper solution would be to cut a hole in the firewall to accommodate the distributor, but I think don't think many people would opt for that these days.
Oh and the cooling system also needs to relocated/modified
04-20-2022, 01:44 PM
Right, for the 20v it used to be a problem indeed to fit it with the distributor. However in Initial D there is no mention of the bulkhead/firewall cutting (or bashing) to make it fit. Maybe due to the dry sump system the engine sits lower with a slight sloped angle and therefore just clears the bulkhead?
04-25-2022, 04:25 PM
Hello everyone,
Thanks for the info. I’m still going to convert my levin to a trueno. If i ever wish to reconvert, it’s always nice to have the option!
Now let’s hope the reconversion doesn’t make the car look uglier than it did in its original state, before converting to a trueno.
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 789 03-05-2023 09:34 PM
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 5,193 07-28-2022 10:48 PM
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 6,100 12-19-2021 11:58 PM
Last Post: gh0st
  Can you identify this wheels? Will they fit AE86? Ryo 8 9,612 09-08-2021 12:48 PM
Last Post: Ryo
  Restoring original pizzacutter center caps banpei 17 7,161 06-24-2021 10:58 PM
