5th gear issue
03-14-2021, 04:44 PM
(This post was last modified: 03-14-2021 05:57 PM by r.ave.)
5th gear issue
Hi Guys,
I seem to have an issue with my gearbox and especially with 5th gear. I'm currently breaking in my rebuilt engine, so I’m not pushing the car at all. When I started breaking in the engine I noticed I had a noise when the clutch pedal was released and the engine was idling. When pressing the pedal, the noise disappeared. So i thought it had something to do with the clutch. Like a release bearing which isn't uncommon with other brands. However, when listened to with a stethoscope on the gearbox, the sound remained to be there no matter what position the clutch pedal had. We checked the gearbox oil, this was completely clean. This noise only occurred when i had been driving for a while and everything was warmed up. Not when cold. The car had been off the road in the winter so started driving it 2 weeks ago. With the previous in mind i kept a close ear if things got worse. It didn't. However, at a certain point I wanted to overtake somebody on the highway. I was doing about 3500revs in 5. I downshifted to 4, increased revs and speed. I noticed the car was smoother, and did not have as much rattling noises of an old car. So I started to checking a few things. I came to the conclusion that the higher I rev in 5th gear (over 3500) i hear and feel some extra noises and unbalance and it increases the higher the revs go, and go down when the revs drop. If I do that in 4th gear, at same car speeds and therefor higher revs i do not notice any difference with lower revs. Same as in 3rd, no difference with 4th. Gearchanges in general are fine, up and down, no leakages. The gearbox has to come off obviously, but would I be looking for just a bearing replacement, or a full overhaul? Looking forward to what you think. |
03-14-2021, 08:52 PM
5th gear issue
I suspect only opening the gearbox will give you a definitive answer.
Every gear has to drive the output shaft, but 5th gear is the one closest to the output bearing (reverse is next in line). So it might have to do with the driven gear being close to the output bearing and your output bearing being shot, but it could just as well be a damaged gearset causing the noise. I'd say give reverse a go and compare it to first gear (similar reduction), but whatever comes out the box will, as you say, have to be opened anyway. And if I had a 40 year old gearbox open I'd try to have some syncro's replaced while I'm at it.. 2nd gear syncro is usually shot. FABRICA MI DIEM, PVNC! |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 1,545 |
Fuel pump issue | DJexor | 11 | 3,793 |
Clutch Issue | Deaty | 8 | 3,559 |
04-09-2021 10:26 PM Last Post: Nakilad |
exhaust odor/idle MOT issue | Ryo | 7 | 6,559 |
Clutch issue ? | izanagi | 22 | 12,079 |
06-06-2019 11:27 AM Last Post: jondee86 |
