Door length
03-18-2014, 10:05 AM
Door length
Can anybody tell me how long an ae86 door is (preferably in cm's)?
If anyone can take a tape measure and check the length at the bottom and perhaps 20 cm's higher I would be most grateful. I need to buy some sheetmetal do create some lower door skins for my project, and would like to avoid having to create a skin out of multiple pieces I can't transport 2 by 1 meter sheets of metal in my little daily driver, so I usually have them cut in half, but I expect the door is longer than 1 meter so I need to know. Think I might also have them bend a lip on two panels for me since my bending brake is only 80cm's wide. FABRICA MI DIEM, PVNC! |
03-18-2014, 11:18 AM
Door length
Hi Ivan,
just measured for you. The bottom: (has curves at either end) between 1257mm and 1265mm 200mm up: 1325mm Widest part I could find (along the indented trim line) measured at 1337mm If you need anymore just ask. hth An analogue brain in a digital World |
03-18-2014, 02:11 PM
Door length
That's all the info I need.. thanks a lot totta!
4AGE 20v Ignition Lead Length | mad.matt | 3 | 6,176 |
ae86 crush sleeve length | choyr | 15 | 19,317 |
02-26-2014 05:03 PM Last Post: choyr |
Length of factory cat | Rick | 4 | 7,169 |
08-07-2013 06:03 AM Last Post: jondee86 |
Valve springs length | Vil | 4 | 5,473 |
04-04-2013 07:41 PM Last Post: oldeskewltoy |
Ae86 accel cable length? | stalker | 1 | 3,359 |
07-30-2011 12:44 PM Last Post: stalker |
