White Kouki Trueno Hatch, 20V BT, FC3S brake, Watanabe MG,
01-03-2011, 03:41 PM
Post: #31
some updates
honda stream brake booster |
01-03-2011, 04:14 PM
Post: #32
some stuffs
redline tail light since the tail light rubber seal is in bad condition, I used rubber that was cut in shape instead Itavolanti Admiral steering (almost 30 yrs old but in mint condition ) |
01-07-2011, 02:43 PM
Post: #33
Question: why did you use a Honda Stream brake booster?
Thanks |
01-07-2011, 03:12 PM
Post: #34
Ozone Wrote:Question: why did you use a Honda Stream brake booster? Hi Because 1.its size is bigger than the OEM one ( 1.5 step) 2. it is the biggest size that can be fitted to hachi without hitting body 3. It can be fitted without any modification |
01-14-2011, 06:47 AM
Post: #35
redlines
interior trd rear wing, just test fit |
01-17-2011, 05:23 PM
Post: #36
Since ther was some member message to me about the water line of the engine,
I took the inlet and outlet of my engine here below If any mistake I would like to say sorry The maintained water outlet line The closed inlet line on the exhaust side. new inlet line at intake side |
01-17-2011, 05:37 PM
Post: #37
Aluminum header adapter to adapt 4age bluetop header to 20v BT block
01-17-2011, 05:39 PM
Post: #38
TRD clutch and flywheel( which I think it is C-one motor sport 4.4kg )
01-24-2011, 04:09 PM
Post: #39
Thanks for the pictures. But have you also pictures of how you made the delco rebuild?
Nice work! Grtz... -------------------------------------------------------- Corolla GT AE86 rally ('87) .... Corolla GT AE86 rally/historic ('83) nog werk aan... Corolla GT AE86 in opbouw ('84) ... |
01-29-2011, 07:43 PM
Post: #40
another pics for engine
after modification the header adapter with waterline hole. another 4AG engine, this one is from this car, put it out, clean and change some essential parts such as timing belt, gasget, seal ETC. Watanabe MG with 195/50/15 BF-Goodrich G-force tire |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 13,203 |
Adam's white, rusty levin...updated 23-09-2018!! | adomz | 150 | 138,540 |
09-23-2018 05:14 PM Last Post: adomz |
86er Levin Hatch from Germany | ArToAE86 | 19 | 15,226 |
01-24-2018 10:35 PM Last Post: ArToAE86 |
Lauren's 1985 Kouki Trueno | Lauren | 161 | 177,580 |
09-01-2015 08:46 PM Last Post: Lauren |
OST-026: "My White Hatch" | oldeskewltoy | 49 | 55,318 |
07-03-2014 11:56 PM Last Post: oldeskewltoy |
