Os7213 Ae86 Project
11-08-2006, 07:47 AM
Os7213 Ae86 Project
Hi guys im new in this forum and want to introduce myself
My name is Ugo im 22yd and im a Machinist. Here my project: (The car remain stock till next summer cause i want all parts ready and do only one complete installation ) Unfortunately its the first time o post here so its hard for to compile all the infos from my origin forum and post it here but some work as been done here and there. NOTE: TO SEE IMAGE IN BIGGER SIZE JUST RIGHT-CLICK OPEN Here the setup for now: Suspension: -Shocks Tokico HTS 102 40mm short stroke -T3 Strut tube+spacers 21.5mm -Ground control coilovers -Eiback springs 8kg front 6kg rear -T3 Top-hat system -T3 Negative camber plates -T3 Negative camber blocks -T3 Tension rods -Ueo style front lower arms -T3 4link+panhard -Ueo style tie-rods end -TRD rack and pinion -Tanabe sway bars -Cusco front tower bar -Cusco rear tower bar -Cusco lower bar -AMT tri-bar Engine (Not yet complete): - 4agze small-port head -20v Itb's -Toda camshaft 272˚ 9mm lift -Toda camgear -Toda spring kit -Toda under-bucket shims kit -Megasquirt Brake: -Project Mu type Ns brake pads front -Project Mu D1 specs brake pads rear -Braided lines -Brembo slotted ,dip-drilled Wheels: SSR speedStar Mesh Ver.B Here some pictures of under the car after some work and cleaning: Interior after welding: And finally some parts: (Up+Down) So that it for now hope you enjoy! Many more to come cause i begin the motor work in few weeks. See ya. Ugo |
11-08-2006, 10:00 AM
Os7213 Ae86 Project
Whow nice little trueno!!!
Love it! Good luck on the work! Looks like she's in good hands there! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
11-08-2006, 10:42 AM
Os7213 Ae86 Project
Smallport head with itbs. Sounds interesting!
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-08-2006, 11:39 AM
Os7213 Ae86 Project
You dont need a project, you car is allready fantastic!
danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
11-08-2006, 12:11 PM
Os7213 Ae86 Project
car looks very clean. Wanne see it when you have all your parts installed :-)
11-08-2006, 10:58 PM
Os7213 Ae86 Project
Thank you all for the good comments
The suspension and direction parts will be installed next spring cause i want to wait till i have all the parts to begin the build up! And for the 16v itb's i will need you help See ya guys |
11-09-2006, 10:06 AM
Os7213 Ae86 Project
There are several members who installed itb on their 16v heads, but i never heard of putting it on a smallport.
About installing the itbs: might put a question up in the technical section when you are up for it. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-10-2006, 08:49 AM
Os7213 Ae86 Project
Thank you i will i think the hardest part will be the porting of the itb+flenge and doing a nice flow line with the port!! Oh btw the flenge is nealy done:
I think that gonna rock But the smallport is for me the best way to do porting job! And smallport have some option that i love like the hole for oil return... so why not! After all its the head see ya guys! Ugo |
06-28-2007, 03:37 PM
Os7213 Ae86 Project
Hi guys!
I know its been a long time but the project moved a little so here the updates: I have change my mind for the flenge here the new one: -Ueo Style tie-rods -Front Cusco ACL-OS -Rear Cusco CB -Cusco Lower brace Type 1 The CB unit is SO LIGHT! Cusco RS 2ways lsd Mounted on Koyo bearings New Toyota Kouki bumpers, lights, grill, emblem, F/R brakets New Toyota gas tank gaskets,bolts and rear end bolts+rebuilt calipers Also got F/R Tanabe sways bars 25.4mm front 20mm rear No pics ;( And the work begin!!! Paint Axels with new Koyo bearings: The gas tank almost finish: So like you can see we begin by the rear end So we will install the new parts, break the lsd and begin the front. Thanks Ugo |
06-28-2007, 04:33 PM
Os7213 Ae86 Project
It seems that it's going to be a nice and clean project :wink: .Nice work so far, but i would like more details...Is this gonna be your everyday car, or do you build it as a trackday project?
