Machining Pistons to run 20v head... And FCR's on a 20v?
09-11-2013, 07:17 PM
Anyone up on this?
I might be running a 20v head on my 16v, is pocketing a high comp 16v forged piston to take the 5th valve something that can be done? Also, anyone ran FCR's on a 20v head? This head has no VVti to worry about, so my current FCR's should theoretically go on with a new inlet manifold and a Dizzy relocation kit.. Right? Ta! Driftworks - JSPFab.com - DangerStyle - NightSpirit |
09-15-2013, 01:08 AM
![]() Quote:At the time I built this engine no one did decomped 5 valve pistons,One Aussi did this when building a 20V turbo engine, so I guess it is possible. Might pay to get an old 16V piston and drill a few holes to see how much meat there is in the dome where you need to cut... and measure the valve to piston clearances very carefully. Cheers... jondee86 |
| 20v BT Head | filh | 4 | 2,667 |
03-11-2025 09:51 PM Last Post: oldeskewltoy |
| 82mm Stock compression Pistons | apardal | 4 | 4,880 |
| Where to run the factory antenna cable | andyling | 2 | 5,382 |
09-30-2020 12:31 PM Last Post: andyling |
| Small Port 10.3 Pistons | Alex170984 | 1 | 5,639 |
| How to install 20V ITB on 16V head | Mr.komp | 7 | 15,050 |
![AEU86 AE86 - Machining Pistons to run 20... on a 20v? [Image: AEU86 AE86 - Machining Pistons to run 20... on a 20v?]](http://img19.imageshack.us/img19/92/pistonj.jpg)
