Kajoba Works 4A-GE 16V dual-plenum intake manifolds
08-07-2015, 01:10 PM
(This post was last modified: 12-05-2017 01:27 PM by kjb.)
![]() ![]() ![]() ![]() ![]() For RWD turbo installations! - velocity stacks - 65mm billet throttle body, black or silver anodized (only black available at the moment) - main plenum displacement 1.5x engine displacement (2.4l) - 4x 4mm hose connections for fuel pressure regulator, gauges, boost controller and whatnot. - 2x 10mm hose connections for brake booster and IAC-valve. - durable black wrinkle paint NOTE! I'll update the photos ASAP to show the black throttle body as well. The benefit of a dual-plenum design is the more equal distribution of air for all cylinders in a turbo application. Usually this comes with a small drop in peak power but also an increase in response and driveability due to a smoother torque curve. Excellent choice for a daily driven / trackday / circuit racing vehicle ![]() Currently out of stock, will update when available again. Kajoba Works [email protected] http://www.kajobaworks.com / http://www.facebook.com/kajobaworks |
08-20-2015, 03:05 PM
Really nice part that, great work
08-20-2015, 07:00 PM
very nice item...
Kajoba Works *E7 & AE86 weld-in chassis braces | kjb | 20 | 35,347 |
04-27-2017 11:27 AM Last Post: fantapants |
Sakura Fab: 4AG Heat Screen Intake Manifold Gasket | dr.occa | 1 | 6,203 |
12-27-2013 07:50 PM Last Post: dr.occa |
K1 MOTOR WORKS KOUKI LEVIN FRONT HEADLIGHT SET **COMPLETE** | yversion | 9 | 13,620 |
07-01-2011 02:27 AM Last Post: yversion |
K1 MOTOR WORKS SWIFT FRONT SPRINGS 8KG | yversion | 1 | 5,452 |
05-17-2011 12:12 AM Last Post: yversion |
Dual Carb T-Shirt Shift Gear S-4XL | tomstwincam | 6 | 7,830 |
11-22-2010 02:24 PM Last Post: tomstwincam |
