ECU problem ?
03-14-2010, 03:20 PM
ECU problem ?
I think what is happening to my engine is a bit odd and I wondered if someone could shed some light on it.
New Bigport 16v engine install, complete TVIS system removed including butterflys etc. Engine starts ok and runs with the engine management light showing, after maybe 20 seconds the engine management light goes out and the engine stops I have read the error codes and it comes back as 2, pressure sensor. I assume this is because the TVIS plug is disconnected ? An analogue brain in a digital World |
03-14-2010, 04:50 PM
ECU problem ?
Sorted
MAP sensor connector not pushed ALL the way in... An analogue brain in a digital World |
4agZe problem solved - 99% IC problem | Okami | 41 | 33,352 |
AC problem? Idle problem? | KD2229 | 3 | 4,424 |
08-19-2009 02:08 AM Last Post: KD2229 |
